P1000 ITP BLACKWATER EVOLUTIONS
Harveyb
15
12
upstate NY
Put 30/10/14s on 14" m12 wheels,any recommendations on air pressure,running 12 now,thanks
Welcome.
8 psi is where I run mine and they have held up to very rocky trails while giving a comfortable ride.
Boss0144
137
147
Commerce Township, MI
You guys that run low pressures (10psi or less) - do you do that with standard wheels or are they bead locks?
I think 8 is recommended pressure. I have dual beadlocks on my 1000 but on my 700 I had standard wheels and ran the same if not less. I run the 1000 a little faster than the 700 so I keep a little more pressure in them to prevent pinch flats.
Harveyb
15
12
upstate NY
Thanks for the reply,will give 8 a try,I know 12 was still a bit stiff.Boss0144 I don't have beadlocks.
CPope
CPope
352
1,152
Pulaski TN
I run 6 in the mountains but I have beadlocks
208,730
I have the same tires and I run 8 psi, but have run 7 psi without an issue in the rocks caring speed, I haver never had a flat with these tire. I have busted side walls with EFX's running 14 psi.
Boss0144
137
147
Thanks guys.
I have terabites and just deluxe wheels. I'm nervous to run them down at 10-12psi for fear of side wall damage or even un seating them off the bead with a hard hit on a rock.
I'm happy to hear (even if it is a different tire) that guys can run them down there without issues. Maybe I'll let a little pressure out!
208,730
Thanks guys.
I wouldn't go below 14 psi in the fronts, I busted an EFX 8ply with 14 psi. The stock front tires are not big enough for serious trail riding, need to go with bigger front tires, but!
Boss0144
137
147
Ha - I'm running 15psi now. But they are 32's! (they measure 31). That should help! It's an awful lot of sidewall!!
208,730
Shoot I would go down to 8 psi in the Black Water's
