Has anyone installed one of these? Seems like a cheap alternative for heat.
JEGS 70611: Auxiliary Heater Assembly 200 CFM, 13,200 BTU - JEGS
HEATER FLOOR MNT 13200BTU
www.jegs.com
The Jegs has 6 as well, there are 2 optional defrost ports on the bottom. The defrost kit is $27 I think. I’ll check out the ice crusher.The price is right. One of the things that is frequently mentioned as an issue with Pioneers is need for windshield defrosting. With this Jegs unit you’re giving up floor space in the cab, but that space isn't that useful in most situations. I ended up buying an Ice Crusher system from UTVHeater.com. It has six outlets including 2 defrost vents. Literally just got it installed, so haven't had a good opportunity to see how well it works yet. I‘m confident it will work well.
Do you have any pics?Mounts under the front clip on the firewall below the batteries. Pretty well engineered, but a tight fit. Certaintly does not compete with the price of the Jegs heater though. It has a factory look and doesnt take up any floor space. The heater is mounted up higher than the ones that have the heater core mounted below the seat that are susceptible to flooding
Which model did you go with?Well just installed jegs heater under the seat.Not the model that your looking at.Install was tuff but not to bad had to make brackets it is mounted like the stock honda install.Tie into oil cooler lines and you have heat in about 2 min.I have 140 degree air coming out in about 10 min seems to work well for now.No defrost vents in mine didnt want to run a hose that far and around the driveshaft.JOE
HEATER FLOOR MNT 13200BTUwww.jegs.com
