P700 Key on harness
bassadict69
31
20
Benton, La
I bought the harness for key on power last year and we are just now getting around to wiring things up.
We did find where this harness hooks up. Does this bypass using some sort of fuse panel?
Anyone have a diagram of how to wire things up? Right now we have a lightbar for the front and also a small winch we are mounting on the overhead bar to assist with lifting deer into the bed.
Hillbillytnt
Hillbillytnt
552
2,030
Ky
I use it as a key on source. As in making relays hot. Then the relay provides the power to the accessory. It prevents things from draining your battery when key is not on. It’s only good for about 15 amps. A winch of any size is going to need to go straight to the battery
67,170
The key-on wire will run a few small accessories.
It should power your small light bar and you will use it for the trigger wire of the winch.
Main winch wires should go to the battery.
