P500 KFI 66" Pro-Series Snow Plow & Mount - 2015-2017 Honda Pioneer 500
RumpRocket
189
295
USA
Any suggestions in finding the best deal?
Reactions: trigger
JCart
JCart
897
2,024
Kamloops, BC Canada.
Try direct from KFI, I couldn’t in Canada had to go through their dealer network. Excellent product been very happy with mine and good choice on size too.
Cheers,
j
dls1966
dls1966
192
569
Kawkawlin Michigan
Just purchased this system last week but I went with the 60 in blade it was under 600 dollars
Seems well worth the money haven't had a chance to use it yet but fingers crossed, I will
They had the KFI winch 3500 hooked up in the showroom and it lifted the plow up instantly...Nice setup
Reactions: RumpRocket
RumpRocket
189
295
USA
I went with the KFI Pro Poly 66 inch Combo Kit, it has everything just over $700.00 on e-bay...that was the cheapest I was able to find, I called KFI and they asked just under $800.00 for the Pro Poly plow, post tube and mount.
The 66 inch metal KFI plows are are about $100.00 cheaper...Thanks everyone.
420Rancher
37
84
Innisfil
I want to switch to a kfi front mount system, i presently have a click and go gen 1 blade. Can anyone tell me the space between the uprights on the kfi blade. My present push tubes are 11” where the blade mounts. The blade i have is a wing blade like the warn pro vantage.
No real specs for any push-tubes online, i remember when we could google to find more than adds.
I mounted the kfi winch mount and was happy with it. The push-tubes seem long for the kfi front mount .
T
Tstover
141
398
Central PA
I just installed a KFI yesterday. The mounts from the push tubes to the mount on the machine are 12 inches apart. Good luck!
155,150
Bring it on Winter, do you know who you're f***** with?!
Plow
T
Tstover
141
398
Central PA
Crap, just reread your post and see you want the blade mount width, let me go measure, be right back..................................11 inches, you’re in luck.
Reactions: 420Rancher
420Rancher
37
84
Innisfil
Thanks for the measurement,
Meant to post some pictures, with the two snow storms over the last two days have had a chance to plow some snow.
This is a great machine to plow snow with. The old blade fit without a problem!
Cant believe how high the blade lifts.
758af2662e584324828f02c48618d8e51df84bb8324ea747a743533b89b9bb46
Reactions: JCart
JCart
JCart
897
2,024
Just noticed on KFI’s site they have a poly plough option with replaceable plough face material, wondering if anyone has retrofitted the poly 1/8” material to a standard plough. Thinking poly material would be much more slippery then coated steel, increasing efficiency? It’s a very good price too!
Thoughts?
Cheers,
jrc
420Rancher
37
84
Innisfil
Thoughts?
Cheers,
jrc
My blade is poly and it is very durable would definitely recommend it.
Reactions: MCDavis and JCart
