Launch control
Mrclean12
Arizona
Hello all,
I am curious if anyone has tried to install the 2021launch control on their 2020 model. Is it just a switch and ECU flash or something that’s not really feasible.
I would really like to be able to add this as I have a ton of aftermarket stuff I’ve put on my talon and don’t really want to buy a 2021 to do it all over again.
HondaTech
I've tried just the switch and an ecm swap with the switch. Nothing works that I've seen yet. Except the Power Commander tune.
PaulF
PaulF
1,462
4,815
It can be done the Dynojet PV3 on a 2019. Call Hess Motorsports and see if it works on the 2020 R.
I believe they use the Sport switch to activate it. Press/release for Sport mode, press and hold for a couple seconds for Launch Control.
Mrclean12
Arizona
I should probably add that I have the Jackson turbo kit installed as well...I’m not sure if I can do a pv3 with the tune from Jackson?
HondaTech
We've talked to someone who's tuned the Jackson kit with a PV3. So there is a way to tune a turbo Talon with it, im sure adding the launch mode isn't a big deal then.
