P1000 Leaf Lifter 8070,
RobertinNevada
RobertinNevada
54
187
Fallon
Fall is on its way and I am going to pick up the massive amount of leaves with this set up. I saw my neighbor use something similar and it works great. The idea is you rake a bunch of leaves onto at 5x7 or 8x10 tarp, gather the corners lift it up and put into a trailer. No leaves are falling yet so I had a 100 pound dead bush that I needed to put into my truck and haul away. Worked like a champ. Haven't done any permanent wiring just used jumper cables to extend the winch wiring to my second battery. There is a hole drilled for the 3rd j hook to go on the end just need to pick one up. Max weight for the hitch is 400 lbs I think so you have to be careful. Pleanty for what I will use it for. Enjoy
Dimensions: 8' vertical piece 7' hotizontial piece
Materials
2500lb winch from HF 55.00
Hitch extension with step HF 25.00
Had the snatch block
J hooks 3/8" 4.00
2"x 2" 095 square stock 60.00
$144
IMG 1657
IMG 1658
IMG 1662
IMG 1663
IMG 1664
IMG 1660
IMG 1661
