No not really, get the product update campaigns completed on both cabin comfort and clutch improvement for free, then $20 ish for water ingestion fix kit. Only other thing you would not have is the thicker foam seats and a shield that deflects hot air from entering shift holes, it to is only a $17 add on.I found a left over new 2016 1000-5 12997.00. I have seen the up dates to the 17, but would that be enough to pass up that kind of deal
Where was the dealer?Some one posted them for $400 more on the 1000-5 Deluxe it would be worth it.
First Welcome! And yes you will need the clutch up date, there's more to it than just clutches, the clutch cover with chamfered oil relief valves and different office for more oil flow to clutches, this is a must! You will also need the water ingestion fix and the heat deflector for the radiator. If you lived up North you wouldn't need the heat deflector. Happy Trails!that is what i just bought was a 2016 1000-3 base for 10,995. in Covington la. list was 14000. and they did the comfort update and have a file if i need to bring in for transmission update
I would suggest if your local dealer gives you a rough time that you would call Honda coustomer service while standing in the service dept.!!Well I pulled the trigger on the 1000-5 yesterday. I drove over 9 hours round trip, but the savings over local dealers was about 1500.00 to 2000.00 They did the the updates before I picked it up. So now I just hope I have no warranty problems, because I am sure the local guys will give me a hard time.
Congrats on your purchase!Well I pulled the trigger on the 1000-5 yesterday. I drove over 9 hours round trip, but the savings over local dealers was about 1500.00 to 2000.00 They did the the updates before I picked it up. So now I just hope I have no warranty problems, because I am sure the local guys will give me a hard time.
If the dealer is not familiar with you, tell them you just moved into the area.
Not everyone is comfortable working on their own equipment, Even more-so when under warranty.
Understood.I meant take it to one you are comfortable with and trust.
I don’t trust my local dealers, so mine is going to one 3hrs away for the clutch update and heat fix. Which is the one I bought from.
IF? You will defiantly need it, unless you use it for a golf cart.that is what i just bought was a 2016 1000-3 base for 10,995. in Covington la. list was 14000. and they did the comfort update and have a file if i need to bring in for transmission update
