P1000 Let there be light
TimG
TimG
OLD SKOOL
792
3,966
Southern Indiana
Is the difference night and day ? seriously, I'm considering converting mine.
Reactions: CumminsPusher
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Yes it's worth it wear rubber gloves when you change them the oil on your skin can make them burn out sooner.
113,739
I bought these 2-1/2 years ago and they work great, night and day difference. Never have had a problem. You don’t have to worry about accidetly touching them, there led and won’t burn out from that. There a direct plug and play for your base P1
DF12191A BFFD 4BDB 84C9 D45AA18B373C
113,739
Yes I looked at them I wanted no fans.
You can’t hear the fans, and they draw very small amount of voltage. I didn’t realize the ones you have are fanless my apologies. I was thinking having the fans were a bonus being there in a fairly sealed area in the rear part of the headlight compartment to keep the air moving so the circuit board dosnt smoke . I would be interested is seeing how the fanless versions work for long periods of use for another option . Keep us posted.
Reactions: Ragnar406 and TimG
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Okay I didn't know either so I'm going to try them out.
OnTheJob
OnTheJob
426
925
Bristol, NY
4ED82189 0A06 4C72 89B9 B6B6D6D31B4F
With the high beams on. Not much of a difference for the LED. I’ll take pictures tonight of the projection.
Reactions: Eltobgi
I bought these 2-1/2 years ago and they work great, night and day difference. Never have had a problem. You don’t have to worry about accidetly touching them, there led and won’t burn out from that. There a direct plug and play for your base P1View attachment 90103
Will those work in the 1000-5 delux??
Reactions: Remington
113,739
No, you already have LED lights it’s built in your headlight. Ours are the plane janes if you will. They use a standard type bulb similar to an automobile
Oh ok, what about my 2016 1000-3?
113,739
D94A12FE 3294 4412 A29F 3A9AED7C3719
I’m not sure on that, it’s got EPS????
If you look at your head light, if it looks like the one in the middle you have LED delux lights, if they look like the ones on the machine you have the standard lights that you can change the bulbs with ether one stated in the beginning of the thread.
Thanks Remi, I’ll give it a look tomorrow!!
Tldrigg
Tldrigg
16
31
Reno
BEAMTECH H13 LED Headlight... https://www.amazon.com/dp/B06XHCQ8KY?tag=sxsweb24-20 this is what I used in the headlights of my base 1000-5 works great. Easy install plug in and let there be light.
I just picked these up and I can tell you I am very impressed. As you can see from the pic the pattern is wider and it is true white. The install took about 5 minutes a light. Thanks for the link sporttrac4x4!
Newled
