P700 lift question?
Cameron
Cameron
15
21
Dundee, OR
Is anyone running a 2" spring spacer lift in combination with the Super ATV 2" suspension lift to get a total of 4 inches of lift? Or any combination like this? How terrible would the ride be?
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
Not many people will use a 2" spring spacer. Most keep it to 1" or less.
If you carry a lot of weight or need maximum articulation (rock crawling or deep ruts) avoid the spacers.
New shocks are the best way to get the lift and have a smooth ride. I know it is costly but...
swsebek
swsebek
2,854
5,835
pa
2 inch spacer and lift will put too much angle on CVs
Gator is correct. Try the 1 inch spacers cause they are cheap and easy... Ideally aftermarket shock and super atv 2 " lift together are about perfect. If you want more then arched a arms and,Or portals.
I myself went with fox shocks and super atv 2" lift and I have 28" tires and It is smooth and I have 13 to 14" clearance.
mohawkhondapower
mohawkhondapower
25
11
k-town
Where do you get these 1” spacers from? Thanks
swsebek
swsebek
2,854
5,835
pa
IMG 3747
Reactions: mohawkhondapower
swsebek
swsebek
2,854
5,835
pa
Don't get any bigger than 1 inch and you only really need the fronts.... I hated the ride with all 4 shocks done and took the rears off... if the rear of yours is slacking increase the adjustment on shock to firm setting
