P1000m5 Light Bar install w/ Power Circuit Board
F
Flyinlow
I apologize if this has been posted before but I could not find it if it was. I am a complete Newb when it comes to wiring and would like to install a 52" light bar up front and 2 cubes in the rear on my 2017 P1000-5. I had the Honda Switch Panel and Power Circuit Board installed at the dealer when I bought it but am not sure how to tie into it? I have searched but am coming up short. DO I need a special harness to tie into it? Any help would be appreciated! Thanks!
Neohio
Neohio
Beast of the East
14,465
72,307
Painesville Ohio
@STRATOSMICRO makes harnesses compatible with the Honda switch plate.
@Hondasxs might have something up his sleeve as well. Maybe check with him first before Stratos.
F
Flyinlow
Thanks! I will reach out to them.
jajohn00
83
156
US
How did your project turn out. I have the Honda switch and PDM set up also. I had to buy the Honda cables at $50 each to use the LED and AUX LED locations in the panel. Then I found out the are using 5 amp fuses. I just wanted to know if it is running your light bar successfully.
