G
Gray8333
6
Knoxville
Hello all!
I just bought my first sxs and need help with wiring the super atv 30” light bar. I have a 2021 pioneer 700-4. The battery is under the passenger seat. The light bar did not have any instructions and I can’t find any YouTube videos with the 2021 model. I hooked the light bar to the battery pos and neg terminals. The rocker switch stays lit whether the key is on or not so I’m assuming I should have hooked the pos cable to a key on switch. Unfortunately I’ve looked everywhere I can see and do not see any post or key on bus terminals on the machines. Any recommendations?
thanks,
Larry Gray
Mudwing
Mudwing
36,959
306,672
The Mud holes
Hello all!
thanks,
Larry Gray
Buy the accessory sub harness from the HondaSxS Store. That will give you key on power.
G
Gray8333
6
Knoxville
Hello all!
thanks,
Larry Gray
I’ll check it out! Thanks.
G
Gray8333
6
Knoxville
According to the specs you can only run an 8 amp act on this harness. I would like a harness that has multiple connections for light bar, winch and other small items no more than 4. Is there other options?
Bigseff23
97
172
Lakeland Florida
You would need to wire that up to a relay if you want to run more than a couple amps through it.
