P1000 Light Bar Mounts
Cattrell
Cattrell
49
81
Church Hill TN
I know there have been a bunch of threads on this before but I am looking for some options for a light bar.
I have been running a 52" curved mounted to my roof for the last year but have ripped it off several times.
I am thinking of either moving it more to the front of the roof and lowering it a few inches (it is below the roof line now) or going with a totally different mount. I was thinking about the lower wind shield area.
Can you share some pictures of how yours is mounted if you are happy with it.
As a side note, almost all of my riding is in the woods with considerable tree contact :)
Thanks for the input !
bigr244
bigr244
136
194
US
I'm perfectly happy with this location. Just an idea for ya 70f5f5f14a53c108c0ae6a82fecb4e6d
Sent from my SM-G935V using Tapatalk
aauman88
aauman88
1,091
2,846
I had 30” inside at top of full windshield. Removed to put flip up split windshield and bought a 54” straight bar and mounting it with PBR brackets that go where cage mounts together. I will be mounting in a day or two and can show pics then
FFF9EB70 7516 4A13 A78C 35C1EA8BC204 1ED94E99 454A 4875 8A69 5CE0D8CAAFAA
Cattrell
Cattrell
49
81
Church Hill TN
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
Cheap one from amazon but it’s stupid bright. Hopefully it lasts
LED Light Bar, AKD Part 54 Inch... https://www.amazon.com/dp/B07H4979T7?tag=sxsweb24-20
Had not thought about that but I may order another set of brackets and try it
I went cheap Amazon too. Good idea to check all those bolts and make sure snug. I actually took mine apart and made sure everything was sealed up. Added some gasket maker to a few spots, was a good hole for water to get in where the wires go in. So far so good.
There’s a guy that makes some to fit between the cage bolts.. I swapped my setup out and don’t use mine anymore
jdgriner
jdgriner
37
100
Pacific Mo
i have a mctunning light bar from amazon, (cheap one).... on my golf cart.... super bright, im absolutely happy with it. everyone joked my golf cart was the brightest out of all the sxs and atvs. they said they could tell it was me because they could see daylight moving through the woods and couldnt hear the motor.
im hoping to get one from for my honda... they have one listed for 52" curved... my side by side is goning to be delivered tomorrow, i hope i can find a way to fit it.... anyone know the distance between the front roll bars? sorry to hijack this post
aauman88
aauman88
1,091
2,846
My 54” straight fits perfect from center roll cage to center roll cage as long as the brackets are able to be reversed(flipped) so a 52” with regular brackets should be just right
aauman88
aauman88
1,091
2,846
I replaced those bolts on a previous mod so didn’t know if stock worked or not, sorry I forgot that part
Reactions: haf
Tundra20
Tundra20
316
813
Arkansas
Top bar is a 20” bottom is a 10” like u most of my riding is in the woods with alot of trails here on our land is a tight fit i just installed the 20” went out last night with it and wrks great with no contact
95F0E06F 35F3 4FF5 9CD3 73E388C419D9
Reactions: haf and Cattrell
OnTheJob
OnTheJob
426
925
Bristol, NY
I ride in a hilly area that has pretty thick woods with lots of low lying brush and vegetation. I bang trees with the roof all the time and try to squeeze under brush so I knew a top mounted light wouldn't work for me. I saw these on a Jeep and thought this might work for me, which it has for the last two years. I bought cheapies on Amazon but now I wouldn't hesitate to put some quality cubes in their place in this location.
IMG 5767
Reactions: haf
Rough country x5’s!!
Reactions: ohanacreek
