P500 Light Bar on OEM roof?
BuckBrewer
32
49
Memphis
Has anyone mounted a light bar directly to the plastic OEM roof? Thinking about adding a 30” light bar to top and was curious if anyone attempted with big washers or something and had any issues with the plastic being strong enough. Seems like I have seen this discussed in the forum previously.
906UP
906UP
12,947
120,497
da Yoop
That's how i did it on the Donkey, think it was a 24" or so light bar, used big fender washers under it, worked great.
BuckBrewer
32
49
Memphis
Thank you for the response. Was curious if this was feasible and I have my answer!
906UP
906UP
12,947
120,497
da Yoop
You'll have no problems, the roof is quite strong
Reactions: Russ989
Buggyman
Buggyman
33,168
285,527
ne. ohio
20 " light bar mounted on the roof of mine with steel plates on the bottom side with no problem. IMG 20170223 173812949 HDR
Duckhunt
I got a double row 13" fastened to the under side of roof. Just to keep low branches from snagging.
Reactions: Solbergbbq
Chuckie3
216
408
New Fairfield ct
Put 24”light bar on mine no problems so far.used big washers also . Don’t think you’ll have a problem.good luck
Buggyman
Buggyman
33,168
285,527
ne. ohio
Off topic but who makes that cab? Thanks
it's the honda cab it was on it when I bought it. if I was going to buy one I would get the alumalite cab.
Reactions: Husker1
154,215
If you do mount one to the roof I'd recommend doing the @jak9922 threaded rod mod. The two side bolts supplied with the light have a tendency to work their way out, had mine swinging by one bolt out on the trail. Happened to Jak too and he came up with the fix. That pic of @ToddH was my old light and you can see his between the two brackets down low. Here it is on my current one, makes it solid. ;)
Visor
Todd627
Todd627
56,047
613,069
MI
Good call @trigger. I totally forgot about you telling me about that.
BuckBrewer
32
49
Memphis
Thanks for the info. Can you explain what you mean by shading of the surface with the bumper mount?
