P500 Lighting Mods, what is out there?
KyGal83
KyGal83
Duchess Sheldon, Daisy, KGB, Natasha, SNS
7,569
76,048
Kentucky
Thinking I would like additional lighting on my P5, besides headlight bulb upgrades. What lighting mods have you done to your machines? Brownie points for pictures.
hallic
hallic
320
1,795
Central MN
MVIMG 20201108 140011
DaddyDubbs
DaddyDubbs
13,756
128,427
There are a lot of choices when it comes to auxiliary lighting, finding the best fit for your application will be the most difficult part of the project. Not saying any one is better than another but I went with the following from Tractor Supply Company - Photos are aux light only without headlights and untouched. I'm sure some other configurations will give more light output, but this has worked for me so far.
Best of luck in your quest for your auxiliary lighting.
Front Aux
Mount - which works great on a Strong-Made front bumper
Winch02
Going down our driveway 20220105 LED AuxOnly  Drive Down
On Road 20220105 LED Aux Only Road
Rear, in case you're interested later on - mounted high, but below roof line
RearLED03
On driveway20220105 LED Rear Drive
DaddyDubbs
DaddyDubbs
13,756
128,427
Front Aux
Going down our driveway View attachment 312014
On Road View attachment 312015
On drivewayView attachment 312016
DaddyDubbs
DaddyDubbs
13,756
128,427
Front Aux
Sorry about the duplicates, I don't know why the links duplicated, I only included one link per page and the original post showed three for each, tried to edit and got it down to two.
Reactions: KyGal83
KyGal83
KyGal83
7,569
76,048
Kentucky
Thank you for sharing those! It is great to see them in use.. totally different perspective.
Reactions: Bigtee
Buggyman
Buggyman
33,516
288,120
ne. ohio
I went with black oak led. 20 " combo spot/flood on the front osram bulbs which is almost to bright 22000 lumen. same light on rear but 6" 8600 lumen. not the cheapest but the owner of the company told me of a guy with one on the front of dodge tk that rear ended a tractor trailer at 55 mph and the light was unbroken and still worked. just an option to check out. family owned in FLA.
IMG 20170107 203318171 IMG 20170223 173709538 IMG 20170107 203402133
KyGal83
KyGal83
7,569
76,048
Kentucky
View attachment 312154 View attachment 312155 View attachment 312156
Wow.. that is impressive, that would be an extremely rough impact! Also I am all about supporting an American Made small business!
wvupsc
wvupsc
180
802
West Virginia
I have to admit that when I plowed snow last week, which was the first time I drove my P520 in the dark, I was shocked at how poor the stock headlights were. I had already installed a forward-facing light bar on the front lip of the Honda hard roof, and was very glad I did. The main reason I installed it was to make sure the plow wasn't blocking the all of the light. The plow could have been one of the reasons the headlights seemed so dim when I plowed. But based on the other night, I would consider a light bar a necessary upgrade on any P520 right from the start, regardless of whether or not you plow. I will probably install a small rear-facing floodlight light bar to help with backing up when plowing. It was very difficult to see through the rear Honda soft panel when backing up in the dark (it was also snowing hard, which might have contributed to the problem).
