Trying to figure out whether or not to load up going forwards or backwards on the trailer (Zieman F-511 single axle). I would like to keep the tongue weight down, but not sure how the weight is distributed on my new P-500, or how to figure it out??
Personally, I load mine facing forward with the weight of the engine over the axle.Trying to figure out whether or not to load up going forwards or backwards on the trailer (Zieman F-511 single axle). I would like to keep the tongue weight down, but not sure how the weight is distributed on my new P-500, or how to figure it out??
Loading on a trlr does matter....Don't really matter . Load it how you like and go ride the damn thing .
If you are looking at a new trailer, you might consider enclosed. I have a 6 x 12 enclosed Lark trailer, Inside dimensions are 11'-4" L (13'-2" to V-nose) x 5'-8" W x 6'-6" H - Door is 5'-3" W x 6'-0-1/2" H. My 2017 fits fine, open trailer side access door, drive in forward, set brake, exit through passenger side. Tie down on 4 corners and your done. Plus I like the "out of sight, out of mind" concept that no one knows whats inside. I did end up getting the EMP aluminum roof because I didn't think the OEM roof would fit. Tongue weight is good with this combination, I did however replace the bias-ply tires with radials and it tracks great behind my Touareg at 75mph.
Looking for enclosed trailer now, 16 ft. Need 75 in high door with OEM roof and 27 tires. Do you like the lark?If you are looking at a new trailer, you might consider enclosed. I have a 6 x 12 enclosed Lark trailer, Inside dimensions are 11'-4" L (13'-2" to V-nose) x 5'-8" W x 6'-6" H - Door is 5'-3" W x 6'-0-1/2" H. My 2017 fits fine, open trailer side access door, drive in forward, set brake, exit through passenger side. Tie down on 4 corners and your done. Plus I like the "out of sight, out of mind" concept that no one knows whats inside. I did end up getting the EMP aluminum roof because I didn't think the OEM roof would fit. Tongue weight is good with this combination, I did however replace the bias-ply tires with radials and it tracks great behind my Touareg at 75mph.
Hi Mudder,Looking for enclosed trailer now, 16 ft. Need 75 in high door with OEM roof and 27 tires. Do you like the lark?
