P1000m5 Looking for stock front A arms
Dave46140
5
New hampshire
Drove my tracked rig through the ice on my lake and bent stock arms on drivers side in the process. Looking for replacements, both upper and lower, drivers side but will consider taking both sides, maybe leftovers from a lift kit install, thanks
Reactions: Biteme and TripleB
Vikes79
Vikes79
SKOL!
10,759
104,391
South Dakota
@JenElio may be able to hook you up!
Gabbas
Gabbas
280
700
Humboldt, Iowa
Also might want to check to make sure you didn't bend the tabs that mount the A-arms. They are a weak point.
Sent from my Pixel 4 using Tapatalk
rickoshea
i was ripping down the lake last winter and hit a deadhead sticking out of the ice.luckily i only broke my track a arm lower mount on the passenger side.tough break bud.
Reactions: Biteme
208,011
Check with @Neohio, I gave him my full set of stocks
Reactions: Biteme
Russ989
Russ989
22,525
146,109
I have a full set but I bet the shipping would be awfully high.
Reactions: Biteme
Dave46140
5
New hampshire
Thanks again for the tip. The upper a arm mount get pulled away from the tubing. Looks like the weld was incomplete, lacked penetration across its entire length. Must bend it back and weld it up. Found a kit with support/skid plate with lower mount brackets I’m going to add. Really disappointed with quality of the frame.
