Hi all. I'm new to the site. Pasting my post on the intro forum here for quick reference:
"I bought a 2019 Pioneer 1000-5 Deluxe in November and installed tracks shortly after along with all the other accessories in the photo, all from Honda. I've also recently installed Harbor Freight LED lights on the roof. My experience thus far has been bittersweet. I've had difficulty shifting to low gear since I bought it and it's also overheated."
I have about 30 hours on the machine, almost exclusively with tracks. The machine overheated on my 3rd ride while running in low gear and high RPM. The coolant system consumed all of the coolant from the reservoir and even after refilling it would continue to overheat. I took it to the shop and they updated the 'fan firmware'. I've read that this is more than just a fan update. I then completely drained the coolant, replaced the thermostat just in case since the system was drained anyway and it's a $30 part, refilled with Honda coolant and haven't had any overheating since. I'm really annoyed that the firmware update wasn't mandated prior to me driving it off the dealer lot.
It's been difficult to shift into low gear since I brought the machine home. I figured it'd break in over time but it actually became more difficult and started to make a grinding sound before finally engaging and remaining in low gear. At some point a few weeks ago, I experienced a strong gear shifting clunk while in low gear. I don't recall if that was the last time I could actually engage low gear but quite likely. Now, I can't access low gear at all. I just hear grinding. High gear and reverse operate fine.
I operate the machine between 6000-7000 ft elevation and haven't abused it and am pretty frustrated that I've had two major problems in the short time I've owned it, especially with all the financial and personal time invested in the accessories. It's in the shop now and I'm waiting on a diagnosis. While it's there, it's also be inspected for the sub-transmission recall with regard to what I think is a potentially missing spacer.
Does anyone know of issues shifting into low gear? I checked the shifting cable adjustment as per the service manual and it seemed fine. I also replaced the engine oil, engine oil filter and DCT oil filter as required in the maintenance schedule. The engine oil and sub-transmission oil levels are fine.
