Check out getting it licensed in South Dakota. You can do it even if your not a resident. I live in FL and did mine there last year.
So your saying license in South Dakota and drive on streets in other states?
Just checked out South Dakota says may not be registered and licensed......Darn
Off-Road Vehicles
Chapter 32-03
An off-road vehicle is any self-propelled, two or more wheeled vehicle designed primarily to be operated on land other than a highway and includes, but is not limited to, all-terrain vehicles, dune buggies and any vehicle whose manufacturer's statement of origin (MSO) or manufacturer's certificate of origin (MCO) states that the vehicle is not for highway use. If the vehicle is used, the certificate of title property transferred to the applicant must be attached.
Complete an Application for Motor Vehicle Title and Registration. The application must be filed in the county of the new applicant's residence. The application must be signed by the record owner(s) or by an authorized agent for the record owner(s). If the application is signed by an authorized agent, a power of attorney document must be attached to verify the appointment.
Off-road vehicles may not be registered and licensed for use upon the highways, but MUST BE TITLED.
Motor vehicle titling and registration fees are done through your local county treasurers office. Click here for all applicable license fees that must be paid to the county treasurer.
How was you able to get the body code changed?I had to have the body code on my title changed, once I accomplished that, it was easy to walk into the bmv and grt plates. Hell, mine has vanity plates on it.
Are you in Ohio?How was you able to get the body code changed?
West Central Indiana here and thanks for the information.Are you in Ohio?
Form DPS1373 for further information, hit FB, join the group "Honda pioneer riders of Ohio" I have it all spelled out over there.
I have 4/137 on mine. No vibration, mine is street legal with car plates on it. I run around town with it all the time.
Running Terrabites. And they are DOT. Ohio does not require DOT tires to be street legal though.What tires are you running and are they DOT?
STI X COMP 30x10x14 dot and run all over stuffIMG_5895
- perry
zero, zip, zilch, nada.Have you had any issues with the 4/137 on your machine?
Where's the best (least expensive) place to buy wheels these days. Looking for a set of black aluminum 15 x 7 4/136 5+2.
Rocky Mountain ATV. Prices are at least competitive and they have a large selection.
www.rockymountainatvmc.com
A note from experience: check the wheels for lug nut issues. Some will only accept narrow spline lug nuts, which may or may not work for you.
