Method 411 wheels and 30 inch BFG installed
Zvanhoo
Zvanhoo
12
19
Boise Idaho
  1. Talon X4
Got the new wheels and tires installed. Went with the Method 411 bead retention wheels with 5+2 offset and 1.5 inch spacers in rear. Stoked together out and ride. Looks beefier for sure and now I can rotate the tires and run a spare.
20200615 100102 20200615 100406 20200613 202710 20200613 133222 20200613 133210
jaymohn
31
34
Cincinnati
Nice. I have the same wheels with red lugs. We’ll see how long the red lugs hold up but man they look good. I went with a 30 inch ITP black waters and love them other than I already punctured the sidewall and hopefully I can repair it. It’s pretty close to the bead, Any advice if I could repair it or just get a new tire.
Zvanhoo
Zvanhoo
12
19
Boise Idaho
  1. Talon X4
Man that sucks on the sidewall. Most the time close to the bead it requires and new tire long term. I bet the red lugs look sweet with the red machine!
PaulF
PaulF
1,462
4,815
I did the same thing a couple years ago. First time out with a brand new set of tires. The cords were still intact so I put a patch over the cut on the inside, put a tube in it and swapped it out with the spare. Worked great as a spare but that is all I would use it for.
If any of the cords are cut, I would not use it even for a spare.
hondabob
1,281
5,088
Prescott Valley, AZ
I have repaired a big cut on a new tire twice. A big patch on the inside and a tube allowed me to wear them out. When you have a spare there is no problem running a repaired tire that has a hole too big to be plugged. If the damage is big enough to have a bulge its best to just replace the tire.
NFA_Fun
NFA_Fun
82
96
Pinetop, Arizona
When you have a few miles on them can you give some feedback?
Curious as to ride on and off road, and noise level on road.
Factory tires on my R drowned out the engine at highway speeds.
Always been a fan of BFG. I need to make a decision soon on tires...
Zvanhoo
Zvanhoo
12
19
Boise Idaho
  1. Talon X4
You bet. Hoping to get it out this weekend and will report back. Around the neighborhood they handle well! Lol. Definitely heavier combo with the tires and wheels than stock but most beefier aftermarkets are.
GreenTX1000R
GreenTX1000R
79
98
Texas
How do you like your wheels and where did you purchase them utv looks awesome. Also do you know if they have a 6+1 offset.
Zvanhoo
Zvanhoo
12
19
Boise Idaho
  1. Talon X4
I really like the wheels. With the bead retention they are suppsed to hold the tire on 40% better than traditional rims and I didn't feel I needed a full beadlock. These are lighter too. I dont believe they have a 6+1 offset but these 5+2 are actually a 38mm offset so really like a 5.5x1.5. I picked them up from kj motorsports online. They where a real bear to get the tires to seat just an fyi. My tire guy was really cuzzing me! Lol
GreenTX1000R
GreenTX1000R
79
98
Texas
Thank you so with your offset are you wider than stock and can you rotate your tires from front to rear and did you have to run a wheel spacer.
Zvanhoo
Zvanhoo
12
19
Boise Idaho
  1. Talon X4
I
I am just about stock width. Between 64 ish and 65 both front and back. 7 inch rims with 30x9.5x15. Yes I ran 1.5 inch spacers in the back and plan to rotate my tires and run the same tire/rim for a spare.
O
OhioPro205
15
Amanda, Ohio
Ea6d48594755d5e634958d1437a12052
I just put these on my 1000-3.
15x7 Method 409 Beadgrip wheelsa 5x2 backspacing with 28x10x15” Kamati Mongrel Tire’s. I ordered as a set and they came mounted. Added 1” spacers to the rear. Huge difference.
Zvanhoo
Zvanhoo
12
19
Boise Idaho
  1. Talon X4
Looks great!! I was very close to going with the 409s instead of the 411s but chose the latter. Both are great wheels and a nice upgrade for sure.
