P500 Mudbusters
William
William
1,442
2,887
Flowood MS
Are the mudbusters fenders easy to put on? What do I have to drill?
SBuckJ
SBuckJ
214
216
Central PA
Very easy in front...Just drill the inner fender well and they use push pins...The rear should be easy too...was rough for me because I have a box bolted to my rear rack. If the rack is clear, it will be simple too...IF you have aftermarket wheels make sure to get the wider front flares...I didn't and it was a waste of money. Enjoy!
William
William
1,442
2,887
Flowood MS
I'm putting on 1" spacers with stock wheels. Should I change my order to wider flares?
SBuckJ
SBuckJ
214
216
Central PA
Definitely...I have offset wheels on the front and, though it helps, I still get muddy with the regular ones. Looking along the side it looks like that the wider would catch all of it.
William
William
1,442
2,887
Flowood MS
Well I got the fenders on and it is not that simple... glad I had help... I will take pics tomorrow, I'm going to sleep!
Reactions: SBuckJ and Eltobgi
William
William
1,442
2,887
Flowood MS
Pics
IMG 7486 IMG 7487 IMG 7489 IMG 7490 IMG 7491 IMG 7492 IMG 7493 IMG 7495
William
William
1,442
2,887
Flowood MS
With 1.5" spacers the extra coverage fenders are perfect. Looks like with a 2" they would work too.
Reactions: ehart814
Redrocket
Redrocket
56
58
Lake City FL
Just ordered a set of extra. Coverage front flares today I have after market wheels with 5+2 offset I sure hope it helps mud or sand is h***!!
Reactions: Willi
208,728
Is that your trailer in the back ground of your pictures? HA!
V
Viking1950
7
54
New Ulm, Mn.
Upgraded tires and wheels with 1.5" spacers, so extensions needed. Fabricated front with sheet metal, and rear with plastic from Menards. Rear has 4" extension, and 3" for front. I didn't want to drill holes in fenders, so fabricated metal brackets bolted to frame. Also they can be removed by removing three bolts for rear ones, and three screws front ones if trail has width restrictions. I don't go trail riding much, mostly cruise my place, and country roads. Painted them with
30127267 10215721399452335 104737437552476160 n1   Copy 2
30707997 10215798565221431 7907444488866365440 n1   Copy
30707462 10215798563261382 9212088968789622784 n1   Copy 2
Blk Bed liner.
mrjeff42
mrjeff42
220
578
lagrange georgia
Upgraded tires and wheels with 1.5" spacers, so extensions needed. Fabricated front with sheet metal, and rear with plastic from Menards. Rear has 4" extension, and 3" for front. I didn't want to drill holes in fenders, so fabricated metal brackets bolted to frame. Also they can be removed by removing three bolts for rear ones, and three screws front ones if trail has width restrictions. I don't go trail riding much, mostly cruise my place, and country roads. Painted them with View attachment 72283 View attachment 72312 View attachment 72313 Blk Bed liner.
those look great....
Reactions: rocmar
Biglen
Biglen
25
51
Mentor ohio
No , bad angle for the picture , they do not hang below skids , I checked after your post lol
Reactions: trigger
Willi
Willi
57
172
Homer NY
I installed the same extra coverage fenders with my 27’s with a 5+2 offset and they work great.
