P1000 My 1000-5 After one year
aauman88
aauman88
1,091
2,846
2.5” front and 1.25 in rear. Run front on soft 1 and rear on middle 2 unless fully loaded and then hard 3 on rear
Reactions: VaHillbilly
aauman88
aauman88
1,091
2,846
Current shop situation. Got a little mess
9470B429 6536 4A7D 9936 108160DC1D6D EF91D166 B10D 44B1 BDE2 76D8EA58C7F6 C9029630 19F7 4071 B173 8AE1F859520A C5E7F327 4317 46C8 8862 25D08EB55522
aauman88
aauman88
1,091
2,846
New 54” straight bar and PBR brackets in. Want shorter light brackets so it’s closer to windshield but I’m happy with setup
785339E4 30A0 422C 83F4 EB18A8FA2346 13715701 FAA9 4545 86F2 09F948EE0E38 D814275D E80F 44D9 B218 2830F3796D8C D251E077 ED6E 4EC4 9AA3 088DDDBAAD6D 740F5DC8 C0A5 4825 AC7B D7E614551174 D1790C9E 00D2 42AE A90C 50BC8515AD04
aauman88
aauman88
1,091
2,846
Working on new snorkel. Ordered the 3” Amazon pipe and used 4” piece of stock air intake from my buddies. It fit extremely tight inside factory pipe, is thin walled and the 3” hose fit perfectly over it. Added the flexible boot and hose clamps just in case. Ran through hole in fender my old snorkel went through and pipe is up high in dash beside cupholder. Should I put FrogSkinz material over end just in case? I will never purposely put my machine in water over dash but we do play deep
AD27E668 C884 45E6 AA4A 3FFDB2C308D3 80D9BD1A D988 4B12 BE94 FE4747F31E0E
aauman88
aauman88
1,091
2,846
Actually decided to move it to the highest part of dash above glove box. There’s no openings above it for water to get but I still may put the FrogSkinz material over it
aauman88
aauman88
1,091
2,846
Another great weekend at lake. The new windshield, roof vents and windshield extender gave unlimited options that did away with all dust in cab and kept everyone comfortable in 100* GA heat
670C5CAC DC0E 4CC9 B86B C021D2734976
aauman88
aauman88
1,091
2,846
Well HMF Titan QS black out exhaust ordered. 450$ after 10% back. Excited for these two additions
Reactions: CumminsPusher
319,115
That exhaust note is badass!
aauman88
aauman88
1,091
2,846
Exhaust is in. Broke both bolts off in the old flange so have standard bolts in the new one without the springs until new bolts come in. Exhaust sounds good but only ran a second before got back inside with family. Do you put the stock heat shield back on the HMF or not?? Bolts I had wouldn’t work with springs on flange so left them off, that will be fine temporary right?
jwfirebird
jwfirebird
927
1,446
western ny
they put those on so you dont melt the plastic in hot areas going slow, so i would definitely replace the heat shield. looks pretty cool
aauman88
aauman88
1,091
2,846
The heat shield bolts to factory exhaust and at first glance didn’t see a way to attach to new exhaust but I will pull it apart and check it next time in the shop
319,115
I wouldn’t put those back on even if you could. I haven’t heard of any problems and none in ours. It runs cooler anyways.
