P1000m3 My dash isn't displaying if I am in 2lock, turf , 4whl or 4lock
sharp
sharp
3,757
14,955
Tennessee
The tile says it all any input?
It will shift into 4wd etc. Before the light comes on. Sometimes it takes a while for the light comes on after the selected mode. Go from turf to 4wd and you will notice that you will be in 4wd with or without the light.
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Mine takes a little to display the changes is yours not showing at? What's your doing
Crow_Hunter
Crow_Hunter
750
836
Riding a Canned Ham.
There is an adjustment under the bed.
P1000 - Park and 2wd lock adjustment
An easy way to remember on the rear cable adjustment is "Turf is tight."
If you put it in neutral and shift the lever into Turf, the rear cable should be tight. Do the same thing in 2WD and the cable will be loose. It should also be loose when you are in Park (as it shifts to 2WD in Park).
Test it in your yard by putting it in each mode and turning sharply.
If you are in 2WD, you should see your drivers side tire in a hard left hand turn tearing up the grass/slipping (It has to turn faster to keep up with the passenger side tire).
If you are in 4WD Lock, you should see the same thing on your front tires as well and it will be noticeably harder to steer.
It is a fairly common problem on most machines. The cables Honda used stretch.
Neohio
Neohio
Beast of the East
13,323
64,637
Painesville Ohio
Lets start by helping us with what is going on.
Is this a new problem?
When did you notice this start?
What were you doing when you noticed it?
The above post is a great start. But if you are having different issues, we can help.
Reactions: Crow_Hunter
JimH1
JimH1
59
102
Duluth MN
Thanks this I know
Reactions: sharp
JimH1
JimH1
59
102
Duluth MN
I noticed it was stuck in 2lock, so I adjusted the the cables in the box under the bed to specs thats when it quit displaying on the dash.
Crow_Hunter
Crow_Hunter
750
836
Unfortunately the specs don't work for every machine, it gets you close but you have to tweak it in on some machines. Mine was like that.
Your cable is probably too tight so now it is stuck in turf mode. You can check that before you adjust again by putting it in 2WD and turning a tight left hand turn. More than likely, you won't see the drivers side wheel do anything. That means you are still in Turf.
Do the neutral check and remember Turf is Tight.
You should be able to get it tweaked in that way. Usually it is only a turn or two off on the rear cable.
Reactions: utvmi
JimH1
JimH1
59
102
Duluth MN
Thanks I will try this.
Reactions: sharp
MNnice
6
MN
Mine never displayed anything but turf mode. At 1060 miles...
Tonight the cable going to the rear pulled out of the ferrule.
Going to the dealer on Monday.
JimH1
JimH1
59
102
Duluth MN
Just a follow up, I bought mine to the dealer and they did the cable adjustment. They told me that Honda has put out a tip on the adjustment which sums up what Crow_Hunter said the marks in the cable housing are just guide lines to the fine tuning. One millimeter of change determines if the display works or not.
Jade
24
72
Initially I had a issue where I could not get into turf mode and when I did I could not get out, took it in for service and the dealer adjusted. Now its always showing Turf, with a lot of work I get into Intelligent 4 wheel drive and seems to be working but if I turn off the key and start it back up, shows turf mode again. Even got stuck in some sand where the front tires were working but the back two were not. Its going in again next week for the third time. Hopefully they'll get it fix for real this time.
Reactions: sharp
