L
Did it start after you had the valves adjusted? If so, you need to take it back and tell them it’s not right.I have a 2016 700-4. I recently had the valves adjusted cause I was getting a little noise. Since then I'm having trouble with it shifting and it seems like it is hitting a rev limiter at speeds anywhere from 8-20 mph. Any advice would be appreciated. Thanks in advance
You need to pull the spark arrester out and make sure it’s clean. Check to make sure your spark plugs aren’t loose and then it’s time to check compression. Did you over fill it by chance?It was low. Which didn't make since because I had recently changed the oil, but after I handed oil it shifted a little better but then noticed a little smoke when I was taking off and now you can smell burnt oil also
No sir I haven'tYou need to pull the spark arrester out and make sure it’s clean. Check to make sure your spark plugs aren’t loose and then it’s time to check compression. Did you over fill it by chance?
Well check those items I listed above and then let us know the results. She may be using some oil.No sir I haven't
