P1000 need little axle help, front CV outer Boot replacement
bucktaker
51
65
sw ohio/ETN
I am replacing the passenger front outer cv boot.
Hub and all removed. Attempted to pull axle out by tapping on the outer CV. The outer cv came off the axle. Replaced the boot and trying to reinstall the outer CV.
There is a snap ring on the axle shaft in the outer groove. I cleaned and regreased the outer cv with new grease.
Do I just align the splines and hammer/mallet the outer cv back on ?
does not seem right to me.
CV did not come apart, all balls and cage in good shape.
Not sure about the outer snap ring on the axle shaft
Reactions: Lady01 and TripleB
TripleB
TripleB
15,619
140,495
Caryville, Tennessee
See if that tells u what u need to know.
bucktaker
51
65
sw ohio/ETN
lol I watched that one before i started it kind of skips over the ring i am concerned about at the 10:xx mark he just whacks it back on
I am not sure how with that ring on the end of the shaft in that groove
Reactions: Lady01
donia
Miss’ippi
It is a circlip...c-clip. Compression fit. There’s a tiny gap before it meets itself that lets it compress with a good force applied to it. Sometimes you have to hold your mouth just right and if that doesn’t work, cuss it good and get a BFH!!
bucktaker
51
65
sw ohio/ETN
that could be my issue my gap is large on the clip . I can try to make it smaller with a vise squeeze
Reactions: Lady01
donia
Miss’ippi
Something I did (the many, many times I changed boots on my old Rhino) was to take a small zip tie to compress the c-clip. It makes it slide in easily and it pushes the zip tie off when sliding in. Just use snips to cut it off of the axle.
208,729
Good tip!
Reactions: Lady01
TripleB
TripleB
15,619
140,495
I sheared a clip in two. Had another fly off in the darkness when I was trying 2 squeeze in down to size. 3rd time was a charm. I guess I was holding my mouth right. Lol. I bought extra now.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Replaced the clip and drove it in. Now on to the clamps. Thanks
This is the tool I like https://www.grainger.com/product/54...ucid=N:N:PS:Paid:GGL:CSM-2295:4P7A1P:20501231
1611187035840
bucktaker
51
65
sw ohio/ETN
I ordered the tool from Amazon that’s in the video. Ended up messing up the clamp. Went to autozone and got a universal cv boot clamp got it all back together. Next time I will just order a replacement axle.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
New axles from Honda come as an outer CV with and shaft and an inner CV. You still have to install the clamps yourself
