28x10x12 Tenson Regulator A/T on all four corners with stock steel wheels? Good idea?
D Drenlin New Member Feb 7, 2021 2 6 3 SEMO Ownership 1000-3 Feb 7, 2021 #1 28x10x12 Tenson Regulator A/T on all four corners with stock steel wheels? Good idea? Reactions: Lady01 and Isaiah
TripleB Well-Known Member Lifetime Member Aug 13, 2018 11,648 98,943 113 Caryville, Tennessee Ownership 1000-31000-5 Feb 7, 2021 #2 It will work. Your front will be wider and the rear will be more narrow. You can run it like that or add a spacer in the rear. You can't rotate them because the rear wheel won't clear on the front without a spacer. Reactions: Lady01, Isaiah, Blownzuki and 2 others
D Drenlin New Member Feb 7, 2021 2 6 3 SEMO Ownership 1000-3 Feb 7, 2021 #3 Ok thanks so a 1” spacer in the back and it’ll be even? Reactions: Lady01, Isaiah, Blownzuki and 1 other person
TripleB Well-Known Member Lifetime Member Aug 13, 2018 11,648 98,943 113 Caryville, Tennessee Ownership 1000-31000-5 Feb 7, 2021 #4 Drenlin said: Ok thanks so a 1” spacer in the back and it’ll be even? Click to expand... That's what I ended up doing and it looked even lol. I never put a tape on it. Reactions: Lady01, Isaiah, Blownzuki and 1 other person
