P1000 New Cooler Mount
G
grizzly660fan
50
86
I just picked up a cooler mount that connects to my Honda bed extender. The mount works with the back seats up for passengers or down in the stowed position. I am really pleased with this and thought you all might also be interested? He has mounts for most popular coolers and I happen to have the Ozark Trail model. Can't wait to try this on a trail ride!
IMG 0528 IMG 0527 IMG 0526 IMG 0525 IMG 0524 IMG 0523 IMG 0522 IMG 0519 IMG 0520 IMG 0521 IMG 0518
JenElio
JenElio
71,196
652,584
Loxahatchee, florida
View attachment 200113 View attachment 200114 View attachment 200115 View attachment 200116 View attachment 200117 View attachment 200118 View attachment 200119 View attachment 200120 View attachment 200121 View attachment 200122 View attachment 200123
Not bad!
Who is "he"?
Reactions: Lady01 and Isaiah
Isaiah
Isaiah
2,191
6,964
Altamont TN
Where did you get that?
Reactions: Lady01 and JenElio
BigtineBowhunter
5
Minnesota
Where did you get that Honda bed extender?
G
grizzly660fan
50
86
How well does it do at holding down the cooler? I tend to get a little rough on the trail! Lol
The cooler full of stuff (drinks and food) is pretty heavy and the weight of that keeps it down. I don't jump my rig but I do run technical trails and some high speed, the cooler doesn't seem to move. I was strapping it down before with ratchet straps and never was able to keep the cooler from moving around before this mount.
Reactions: Lady01 and Caddy
Caddy
Caddy
Rosewood, Ohio
I ordered a set and they should be here saturday! Thanks for the heads up! I'll add some pics of mine once I get them installed.
Caddy
Caddy
Rosewood, Ohio
It's been awhile and I forgot to post my followup.... I don't have any pics at the moment but I did run into a couple of issues.
1. There is a thumb screw that attaches the cooler plate to the arm. They would work themselves loose and found one had fell out! (luckily I found it still in the bed) Had to check and retighten on each stop.
2. The arms don't grip the bed extender very well. Used some rubber tape and wrapped the bar of the extender. It helped but the arms would still move up allowing the cooler to get sloppy. The lid of the cooler was basically the only thing keeping it attached... Used an extra strap help pull the arms down and tight to cooler while on the trail. Which worked great. I plan to get ahold of Brandon about adding a second arm on each side to help secure the up and down swing of the arms...
Otherwise these are great! I ride some pretty rough trails and put it to the test for sure... As anything, there is always room for improvement!
I'll post again with any updates to fixes...
Reactions: Mudwing and Lady01
G
grizzly660fan
50
86
I have had mine for about a year now and still really like it. I have not had the issue of the thumb screws going loose but I added a split washer to mine and maybe that helps keep it tight? Mine is bound down tight onto the bed extender and if I bang on them I can move one but they stay pretty tight. I have never had to tighten or adjust the arms that reach out to the plates that go to the cooler.
I hope you get yours resolved and the rubber tape is the solution.
I would purchase again if I needed to.
Reactions: Caddy and Lady01
