New Engine Performance Options for our Talons
SLOWPOKE693
SLOWPOKE693
1,866
7,358
Somewhere in Texas
I've been looking around the web for ways to increase the HP on the Talon beyond an exhaust and store bought tune. Im building mine to race in an N/A class that has no engine restrictions other than no turbos, superchargers or nitrous allowed, so the sky is the limit. In my search I came across a couple companies that look promising if anybody else is intrested...
WWW.JSDMACHINEWORKS.COM
-Stock bore high compression CP pistons
-Kibblewhite + 1mm intake & Exhaust valves
-Stock bore 9 - 1 compression turbo pistons
-Carrillo H beam Rods (Turbo applications)
WWW.DANIELCROWERRACING.COM
-Performance Camshaft
I think combining an 11.5 -1 compression ratio piston with a slightly decked head, to get closer to 12-1compression ratio, combined with a ported head, bigger valves and the DCR camshaft would be a kick azz setup for a race motor. Tune it with VP110 race gas so timing could be maximized, and I bet that motor would ripp!
Another thing I would add to a wish list would be bigger bore throttle body's and slightly bigger injectors.
A few years ago I sent my KTM throttle body to a company in California, based on my dealers recommendation, that bored it oversize, profiled the throttle shaft and installed a new thinner larger throttle plate to fit the bore. They also installed a bigger cc injector. I had the bike dyno tuned at the KTM dealer after and it was an impressive difference with no other mods. I could see the Talon benefitting from this same modification.
Thoughts?
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
Thoughts?
Sounds awesome!!! do it and get back to us with dyno numbers
Michigander
Michigander
90
174
I'd talk to Complete Offroad Performance out of TX also.
SLOWPOKE693
SLOWPOKE693
1,866
7,358
Somewhere in Texas
Care to post a link to their website. I googled that name and only came up with a 4x4 shop with no SxS related content on their site.
Also, may I ask why I should check them out? Do they make performance related products for Talons? I live in Texas and travel all over this state and others for work. Its always cool to stop and check out new shops when I'm on the road. :cool:
