New Mt member
MtClimber500
MtClimber500
62
170
Butte, Mt
Am a new member from Mt. I have a new Pioneer 500. Was real lucky to get one. Right now there are none to be had anywhere.
Need the 50 inch wheelbase to run the forest service trails out here. Love the Pioneer. Is a little bit tall so have to watch the trees and could use better headlights with dim and bright.
Has anyone put in the front diff lock modification and do you like it?
How do you add a picture to your account profile?
2020 Honda Hunt2
MtClimber500
MtClimber500
62
170
Butte, Mt
Welcome from west central Fl. I just replaced headlights with L.E.D. It was an easy swap much brighter now. have not tried them at night yet.
Thanks, I was wondering if L E D bulbs could be put in. Where did you get them.
Reactions: TxDoc
F
Fischer
209
321
The woods
Riding in Mt as well, unless you really get off the rails.... you might not need it. Test your boundaries, then decide.
Reactions: Mopower58 and TxDoc
DaddyDubbs
DaddyDubbs
13,714
128,050
Welcome from Alabama.
I have the front diff lock installed and I'm very pleased with it, at the same time I also installed an EPS (electric power steering) which while not necessary makes driving the P5 much nicer.
As @HiFive mentioned, the LED headlight conversion is very simple and inexpensive.
If you check out this post A new P500...this weekend! - The Honda Side by Side Club! and go to post #36 you can see a comparison of the OEM lights and LED lights
Reactions: TxDoc
Homer
Homer
Bad Decision Coordinator
1,000
12,608
GA
Welcome from NE Ga. Helpful group here.
Reactions: TxDoc
MtClimber500
MtClimber500
62
170
Butte, Mt
Thanks, I already have the power steering. Have been on some snowy icy steep hills where I could use both front wheels pulling. Where did you get the diff lock mod installed?
Checked out the LED light posts. Will try some and see if I get better night vision.
I have a regular ATV with a front diff lock. Makes a big difference when stuck or spinning.
Reactions: TxDoc
Mudwing
Mudwing
36,959
306,563
The Mud holes
Welcome from the mud holes of WNY. The 5hundo is a true billy goat. Enjoy. 😉
#ntc😎
208,011
WELCOME from NW Arkansas!
