NEW PULL PLATE FOR TALON
HavasuDave
HavasuDave
164
307
Arizona
New pull plate by S3(System 3 off-road). Much better way to strap down versus the loop. Got it at Just Money Motorsports. John helped me with install, the holes are drilled exact and you have to jack it up for holes to line up. They are great at Just Money!
IMG 8736
F
Fyathyrio
235
649
May be the pix angle, but that looks like they reused the stock fasteners and now the nuts aren't fully engaged on the bolt threads. If that is the case, then this probably isn't a much better way to strap down or anything else.
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
Yep.
My KFI hitch was $63 and came with longer bolts and new nyloc nuts.
also works for tiedown points.
covers and protects the rear diff sensor better to boot.
(made in USA just like S3)
Reactions: TripleB and Isaiah
HavasuDave
HavasuDave
164
307
Arizona
Yep.
Do you have a photo, I am not familiar.thanks
Reactions: Isaiah
HavasuDave
HavasuDave
164
307
Arizona
You're right, probably should have come with longer bolts.
Reactions: Isaiah
