P1000 New rims and tires options / issues
rndbbls
rndbbls
10
19
SoCal
I have a 2018 1000-3. Tires are worn out, was thinking about going with 30x10-14 tires and rims.
There is an option on offset 5+2 or 4+3. What offset should I go with and what clearance issues
may I have with this new size set-up. rndbbls
Amre2me2
Amre2me2
381
1,423
Colorado
Need to know if you have Fox shocks and a Bracket lift? Fox shocks have an external cylinder that will rub in the rear If you have a bracket lift, even with 28s. So you have to use a spacer or get rims that are 4:3 offset. The front shocks, there’s room to turn them 180 degrees to clear.
Reactions: Isaiah
JenElio
JenElio
74,944
676,395
Loxahatchee, florida
Well welcome to the club.
If you are going anything bigger then 28s (30s) you can just get forward arched a-arms from @SuperATV. Most people do the 5+2 offset and a spacer kit. 1" up front and 1.5" for rear.
Remember pics or it didn't happen!
#NTC
rndbbls
rndbbls
10
19
SoCal
It does not have Fox shocks or a lift.
Reactions: Isaiah
rndbbls
rndbbls
10
19
SoCal
#NTC
Thank you for the reply.
Reactions: Isaiah
Mopower58
Mopower58
Unburdened by what has been!
81,215
717,455
Crystal Springs,Ms.
Welcome to the club from Mississippi. I went with 5+2 14 inch wheels and 28x14x9 and 28x14x11 on mine,no lift or a-arms on mine, factory skid plate and no rubbing. The tires are BigHorn 2.0's. I have RB-3 Off-road 1 inch wheel spacers on the rear only to even up the track width.
IMG 0212
ReillyFarrel
ReillyFarrel
22
16
Labrador, Canada
I have a Portal lift with hightlifter from SuperATV with 32x10Rx14 Mudder Inlaws for sale.
Reactions: Isaiah
SuperMidget
SuperMidget
100
362
AR
I have those same wheels sitting in the boxes stacked up in the dining room waiting for my wifes Cfab lift to show up so i can mount her tires and put everything together. Got red lug nuts to go along with them. The wait is killing her.
Mopower58
Mopower58
81,215
717,455
Crystal Springs,Ms.
I never was much on black rims but these I liked. Y'all made the right decision!
SuperMidget
SuperMidget
100
362
AR
Red is my wifes favorite color....
Hers is a 2018 1000-5 base model so mostly black with red hood. Cfab lift is coming in red, red/back wheels, red lug nuts, rgb led's on the roll cage usually on solid red, red PBR switchplate, red fair lead and synthetic winch rope on her new badlands zxr 5k... There is kinda a theme going on here these days so if a part i look at doesn't come in black or red i don't even show it to her anymore.
Mopower58
Mopower58
81,215
717,455
Crystal Springs,Ms.
Like a lot of people say,Happy Wife=Happy Life or Happy Spouse=Happy House! That ought to look good!
SuperMidget
SuperMidget
100
362
AR
I sold all the stereo equipment in my truck to fund the build, she better be happy!
Riding around the local areas we know all was fine but after recently taking her to Hillarosa and Muddy Bottoms she was having a tough time keeping up with some of our friends built rides with her old silverbacks and more recently on the 28" OG Outlaws that belong on my 4 wheeler while its down waiting on parts. So 3" Cfab lift and 31" OG Outlaws are going on to help keep the belly up off the ground a little bit.
t-bear
t-bear
NE OK
2019 P1K5 Base Model. All stock.
Method 409 Bead Grip = 14x7
Tensor Regulator = 28-10x14
1" RB3 Offroad Spacers = Rear
Love this set-up. Matching spare too so I can do a 5 tire rotation. No rubbing or interference.
20200705 102354
Reactions: Mudwing
