Y
Just put on 27x11x14 ripsaws all around mounted on 14x7 4+3 Vision 551 wheels. Love the new look.
Looks really good!!Just put on 27x11x14 ripsaws all around mounted on 14x7 4+3 Vision 551 wheels. Love the new look.
View attachment 105788 View attachment 105789 View attachment 105790
Sexy! Is the front now wider than the rear
Looks great and bet it will be throwing mud everywhere this coming Spring/Summer....
Thank you, I really like them as well. Just need to deflate the tires.Looks really good!!
I hope so, need top get a windshield wiper. Haven't found one that does the whole windshield.
No rubbing. Just did a test run.I like it. Do they rub at all??
Thank you for the heads up and I will definitely look into them both.Welcome to the forum. Rig looks Nice. Check out Mudbuster wide fenders, helped a lot and the smooth surface in the front wheel well makes for an easier spray off. Also several homemade fender options on forum search. Pleased with a 18 in (450 mm) wiper on other sxs, two more on the way for the P500, several vendor options for under $10.
View attachment 105911 View attachment 105914 View attachment 105915
Just measured, front width 55". Rear width 54".Sexy! Is the front now wider than the rear
I run the 14” Vision and 26” x 11” RipSaws and measure 54” in the rear as well! But have 26” x 9” on the front! I did not measure the front but looked at tracks in the snow and it looks like the front is the same width.Just measured, front width 55". Rear width 54".
Good to know. I would have thought that 9s would have been slightly smaller. Makes sense that the hubs would be pushed out more in the front to accommodate smaller stock tires.I run the 14” Vision and 26” x 11” RipSaws and measure 54” in the rear as well! But have 26” x 9” on the front! I did not measure the front but looked at tracks in the snow and it looks like the front is the same width.
