Multi New Utility Trailer Build
SuperYeti
SuperYeti
220
375
Vancouver, BC
I built a new utility trailer over the winter, and finally got to put it through it's paces this weekend, overall it worked awesome! I'll be following up later with build photos and stuff, but here's a pic of it finished hauling brush and debris this weekend as a teaser.
20170611 095159 zpsfogpgic9
SuperYeti
SuperYeti
220
375
Vancouver, BC
Sorry for the delay getting back to this, been a busy summer.
So the story started with me finding a free trailer on one of the hunting forums I hang out on close to me, I went to pick it up, and discovered it wasn't functional, but I had wanted to build a trailer for a while, and it gave me enough of a starting point to get the WAF (Wife Acceptance Factor) to acceptable levels, so off I went.
IMG 20161014 071004
Reactions: moparornocar
SuperYeti
SuperYeti
220
375
Vancouver, BC
Got it home, realized i couldn't get it into my garage to my winch with the existing axle on, and it was pretty pooched, and was a drop axle that I didn't want anyways, so I cut it off, and backed into the garage and hoisted off.
IMG 20161015 195614
The existing "frame" for the axle and draw bars were pretty hokey, and all bent anyways, so it all came off, ready to start stripping all the crap off the frame, and get it ready to weld the new sub frame in.
IMG 20161016 150444
SuperYeti
SuperYeti
220
375
Vancouver, BC
I decided I wanted the trailer to be axle under deck to give me more clearance, and better support my idea to have walking beam axles that could mount to the new axle spindles so I started building a frame with enough lift to get the tires and axle from a salvaged boat trailer I had kicking around underneath and clearanced.
IMG 20161017 142047
I also decided I wanted to make it a removable draw bar design for storage and transport, and also to allow for different rise drawbars to be used when towing behind the truck, behind the trailer, with a high rise drawbar to better clear obstacles. I used receiver tube for this, adding to the overall strength as well.
IMG 20161028 202003
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
Here's a little trailer I built to tow camping supplies behind the Pioneer. We will also use it for road trips as extra storage space for the kids crap.
IMG 20170903 165500283
Reactions: Tigermark
SuperYeti
SuperYeti
220
375
Vancouver, BC
Here I've finished welding up the triangle for the draw bar. Whoever built the original trailer cut and bent the angle in the corners, and then never welded it, so the new frame picked up everything, and tied it all together with some fat flux core welds to burn through all the old rust
IMG 20161028 222409
Mocking up the new spring hangers
IMG 20161102 230714
SuperYeti
SuperYeti
220
375
Vancouver, BC
Laying out the axle, and squaring everything up before welding in the spring hangersand cut down the axle
IMG 20161107 221116
Out came the light saber and carved off the existing spindles and mounts for shortening the axle, I decided to do it this way, instead of trying to piss around with shortening the axle in the center, that and I flipped the spindles to get more lift.
IMG 20161111 111706
SuperYeti
SuperYeti
220
375
Vancouver, BC
Once the spindles were free, pulled them apart to check, and start grinding and preparing to weld. When I opened them up I found this...
IMG 20161111 111828 IMG 20161111 125608
Once I cleaned them up, the races needed replacing, but the spindles were fine, so onwards.
IMG 20161111 124707
I leveled the axle and clamped it to the trailer and then proceeded to level and square everything against that reference plane. It worked pretty well, and got the axle almost perfect. Ended up getting a bit of shrinkage that pulled the camber in too much, so a little heat straightening and ready to rock
IMG 20161120 172754
IMG 20161120 192520 IMG 20161120 192611 IMG 20161120 193932
SuperYeti
SuperYeti
220
375
Vancouver, BC
First time on the wheels, looking good
IMG 20161121 165552
Primed, then painted flat black shooting a tremclad mix out of my gun
IMG 20161211 111853 IMG 20161227 095059
Went with 3/4" plywood for decking, attached tailgate, and added in chains and latches.
IMG 20170212 132718
IMG 20170212 145003 IMG 20170212 160030
Here it is just about done lights mounted and wired, and ready for final paint and sealing
IMG 20170225 122841
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
Nice! Job well done. I do wonder though, it looks like there isn't much clearance between the wheel and the deck, any issues with it rubbing when loaded down?
SuperYeti
SuperYeti
220
375
Vancouver, BC
Not yet. It's a 3500lb axle, and 2000lb springs per side, I haven't been able to load it up enough to get it to move at all so far. It's a little rough riding as a result. If it does, I'll go with a smaller wheel/tire combo, or just bite the bullet and build the walking beams.
