T
Can I buy new wheels and tires and still maintain the 68" width on a Talon R? If so, where do I find them? Specs? Manufacturer? Dealer? Etc.
No. Even with 6+1 in the front, you will be at about 69.5" wide in front because the stock rims are only 6.5" wide and the tires are only 9" wide. Once you put 6+1 7" wheels and 10" wide tires, you will add 1.5" to the width.Can I buy new wheels and tires and still maintain the 68" width on a Talon R? If so, where do I find them? Specs? Manufacturer? Dealer? Etc.
Thanks for you input. It has been difficult through the pandemic times to find anyone with the willingness or knowledge to help. I ended up buying new wheels and tires that a dealership had on the floor. Front System 3 SB 4's, dealer said 6+1, manufacturer's chart shows 5.5+1, Rear 4+3 with ITP Ultracross 30x10r15 all around. Now I am 71.5 in front and 70.5 in back. I am wondering if there is a way to get back under 70" without a complete loss of my investment? There are trail systems in my area with 70" gates.No. Even with 6+1 in the front, you will be at about 69.5" wide in front because the stock rims are only 6.5" wide and the tires are only 9" wide. Once you put 6+1 7" wheels and 10" wide tires, you will add 1.5" to the width.
The closest you can get is to use stock front wheels all the way around, 1.5" spacers in the rear and 9.5" wide tires. you will end up about 1/2" wider that way.
That tire/wheel combo should net you 70.2" in front and 69.2" rear. The lower the machine sits, the wider it becomes. Have you added a lot of accessories? Have you checked your ride height?Thanks for you input. It has been difficult through the pandemic times to find anyone with the willingness or knowledge to help. I ended up buying new wheels and tires that a dealership had on the floor. Front System 3 SB 4's, dealer said 6+1, manufacturer's chart shows 5.5+1, Rear 4+3 with ITP Ultracross 30x10r15 all around. Now I am 71.5 in front and 70.5 in back. I am wondering if there is a way to get back under 70" without a complete loss of my investment? There are trail systems in my area with 70" gates.
Not really added much. How do I check my ride height? What can I do about it?
I watched a couple YouTube videos, taught me everything I knowPaul, this is great stuff how do you know all this.
