Time to add another item to the list of issues with my '16 P1000-5 DLX.
Driving the Pioneer through deep snow a couple months ago something went haywire in the transmission and the machine jumped out of low range gear. Not sure if snow packed inside and somehow the gear cable system had movement or snow pack to prevent full gear shift, but that was the start of the issue. Fast forward to last week. More snow, went down a steep incline in deep snow and the machine lost low range again, and this time something epic happened in what I believe is the sub-transmission. Machine clunked very hard out of gear and now it grinds a gear. When the transmission is warm it will shift into low gear, but fall out of gear with the slightest movement in forward motion.
I inspected all the cables to the gear shift on the sub-transmission and everything looks fine and the cable did not need adjustment. However, upon inspection it appears the sub-transmission and engine "float" together when the engine runs. It appears there is slight movement and the cable and transmission don't see eye to eye and it may have come disengaged when the Pioneer was on uneven ground. I have the gear issues when the machine is in rough, uneven terrain.
I then drained the sub-transmission oil and found it is quite dirty; dark grey in color. I flushed out all the oil I could. I did not find any metal in the oil with a magnet.
Is it possible the a shift fork failed in the sub-transmission? Has anyone seen this?
There are no codes, never had a code.
All the factory recalls and updates have been done.
I plan to bring it to the dealer, but hoping it won't cost an arm and a leg..
