P700 Noisy steering wheel!
Russ989
Russ989
22,642
147,257
410B4853 C0B2 494C B7E2 043F1478D610
So after trail riding earlier this month, I noticed my steering wheel making all kinds of racket. I kept driving it that way until yesterday when I finally couldn’t take it anymore. After taking the steering wheel off, I found the problem. The rubber seal under the collar was dry. Easy fix, took like 10 minutes. Just dab some white lithium grease on the seal.
HondaTech
Squeaks like a stuck rat dont it?
I always took the wheel off at set-up and regressed these, barely to no grease from the factory usually.
Reactions: Deluxe700
Russ989
Russ989
22,642
147,257
You got that right. I was honestly shocked at how dry it really was.
allgm1
allgm1
1,049
1,484
New Hampshire
mine doesn't make any noise yet,looks like I better check it before it starts.
HondaTech
Had a 1000 Saturday with this issue and was shocked to find the cover and seal already coated In grease.
Digging further I found the rubber boot covering the steering shaft input into the steering rack being the culprit. It was pretty obvious that this unit had been through some higher water though. Its possible it was dried out or had dirt under it. I hosed it down with penetrating lube and it lessened but would need pulled up and properly greased to quieten it completely.
Russ989
Russ989
22,642
147,257
Pretty surprising considering Honda is usually on point with attention to detail.
pioneer_titan
pioneer_titan
21
39
Sheridan, Arkansas
Hadn't noticed that mine was squeaking until i read this thread, its a noisy machine as it is, but checked it yesterday and sure enough the seal was bone dry, one less noise to deal with now.
Russ989
Russ989
22,642
147,257
Lol, mine sounded like a pig squealing. Definitely noticeable.
