Multi Note your key code
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
Lost one of two keys and reviewed some threads for a lesson learned. So just added my Pioneer to my phone contact list with the key code, just incase I loose the second key.
3B6EFA6B 3A01 4653 83AB 0D55A578B119
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
I had dealer put in owners manual but like the phone thing
Reactions: Mudwing
HondaTech
Wonder if the ignition switch has the code stamped on it like the ATVS?
If it does, you can just pull the switch out and cut it off that.
Or if your dealer is good enough to record the code in their system, then they can cut one easily.
Reactions: BWAF
Mudder
Mudder
11,692
88,500
So went to dealer to get replacement key. They would not make one based on just the key code, they would only make a duplicate from an original key. Don’t know if this was just a local dealer policy for anti-theft or if a Honda policy. If true, always keep a spare key in a safe place. Factory key is in my safe if needed again for a clean copy, copy cut key in use.
BrassHatDiver
BrassHatDiver
SE Florida
mind if I ask, how much did they charge you for a new key?
thanks
