P1000m5 Oh “Karen”
Plante11
Plante11
45
110
Maine
A couple of weeks ago my wife and I took the plunge and bought a new family toy! 2017 Pioneer 1000-5 bought used with 500 miles/65 hours. From the dealer the following was installed:
-OEM Hard Top
-OEM Split windshield
-OEM Switch panel
-OEM Volt meter
-OEM Heater
-4500 lb Warn Winch, controls in glove box
-OEM Soft Enclosure, front and back
-LED Headlights
-OEM Skid plate
The kids named the rig Karen, I am assuming after the memes so they can complain or complement Karen as we go.
It’s going to be a very slow do it as I need it build and I hope that’s alright, but I was looking to document it somewhere!
8811247A B4F3 48DE AFB5 9476FA4FEB65 09F82CB0 0736 4757 9994 E9DCD6692D08 E2BB36C9 3736 4625 9A18 EC878CF74539 647266AC F646 4F22 900F FD6DBF7D7BF5 9496328B F84B 443D B963 8FE58113F5CF 465D7D64 05FA 436E 8D6F A3CEAE1F9319
Plante11
Plante11
45
110
Maine
After the first 30 mile ride....I finally get the heat issue
-We stripped the split windshield off mid ride, as well as the entire soft enclosure. If anyone is in a pinch, the OEM split windshield will mount on the back of the roll cage using the clamps and a few zip ties.
We fit just fine down the southern Maine trails we took, which was a concern of mine, everyone said it would be to tight.
In the following weeks I plan to add a few things
-Vent lines
-In bed storage
-Fans
-Heat shields
E96228C0 F55D 489E 9587 2295367C1D8A
208,729
-OEM Hard Top
-OEM Switch panel
-OEM Volt meter
-OEM Heater
-LED Headlights
-OEM Skid plate
View attachment 211329 View attachment 211330 View attachment 211331 View attachment 211332 View attachment 211333 View attachment 211335
WELCOME from NW Arkansas! Great looking buggy! May i suggest real skids as your next investment?
Plante11
Plante11
45
110
Maine
Vent lines are done, this was number 1 on my list.
I also added some in bed storage to store some essentials. My plan is to have the following on me at all times:
-fuel
-spare tire
-extra lug nuts
-valve stems
-compressor
-tire plugs
-Impact
-Impact sockets
-flashlights
-sockets, wrenches, hex, torx, etc
-first aid kit
-Hand chainsaw
-recovery rope
-tree saver and clevis
-zip ties
-fender rivets
-duct tape
-bungee cords and ratchet straps
-WD40
-GPS
-Machete
-lighter
-flint striker
-petroleum jelly soaked cotton balls
-Toilet paper
-fire extinguisher
-gloves
-baby wet wipes
-valve stem removal and install tool
-Lithium jump pack
-Enough gear oil for one diff
-heim joint
-max and mini fuses
-10 ft spare wiring
-Red blue and yellow butt connectors
-Electrical tape
-Wire stripers and crimper
-tire gauge
-Trail marker tape
-2 gallon collapsing bucket
-Spare uni air filter
-Vise grips
-1 qt brake fluid
-3 sizes of hose clamps
-Assortment kit of cotter pins
105,595
-fuel
-spare tire
-extra lug nuts
-valve stems
-compressor
-tire plugs
-Impact
-Impact sockets
-flashlights
-first aid kit
-Hand chainsaw
-recovery rope
-zip ties
-fender rivets
-duct tape
-WD40
-GPS
-Machete
-lighter
-flint striker
-Toilet paper
-fire extinguisher
-gloves
-baby wet wipes
-Lithium jump pack
-heim joint
-max and mini fuses
-10 ft spare wiring
-Electrical tape
-tire gauge
-Trail marker tape
-Vise grips
-1 qt brake fluid
DUDE, Where's your Anti-Plasmatic Prism View Flesh Eating Electrolyzer Cannon? I mean DUDE, WTF? I mean c'mon, it's the new thing and everyone has one. Are you gonna be the guy that stands out and screams LOOK AT ME!?!?!? Gotta be different do ye? Gonna paint it pink next? A nail that stands up....
208,729
Ok, I want the recipe for what you had for dinner! HA!😍
Plante11
Plante11
45
110
Maine
Bed Storage addition
-First I popped off the Deluxe Bed panels
-Used a palm router to open up the holes in the panel to fit the push pin button
-Screwed the ball end of the push pins into the existing locations (it doesn’t seem like the screw right in, but they do. There’s just a cap on the back side you have to get thru. I used my drill and wound them home)
-Used an oscillating tool to cut the opening in the bed
-Measured out where I wanted the hinge that I got from the hardware store and cut in half (I went 3/8” from the bottom of the panel)
-Transferred the holes from the hinge to the panel (Tip..if there’s dried mud on your machine it makes it easier to see the marks for drilling)
-Attached the panel to the SxS to line drill the holes
-Drilled a 3/16” hole for the rivet
-Used a razor blade to trim the lip off the panel
-Attached the Hinge to the SxS first
-Then attached the hinge to the panel
I only used 4 push pins per side, the others are for looks. I have the actual locking pins on the 4 corners.
A few of the things I’m going to have in the pockets
-Hand tools
-Ryobi 1/2” impact
-knives
-Imazing 2500A 20,000mAH Jump pack https://www.amazon.com/dp/B07L5HPVJZ/?tag=sxsweb24-20
-First aid kit (HSA eligible FYI)
-Tire Repair kit Amazon.com: ORCISH 98Pcs Tire Repair Plug Kit Heavy Duty Flat Tire Repair Kit Universal Tire Repair Tools & Tire Repair Set for Car Motorcycle Truck RV Jeep ATV Tractor Trailer Tire Patch Kits Puncture Repair Kit: Automotive
-VIAIR 87P Air Compressor
Next is going to be the cooling fans and heat shields, just waiting on the mail person!
0559CBB7 1856 450B BDCD 61E823A3FBC3 09BB2471 DC21 4E6B 800F A14C23804790 0D2524A0 005E 4AE9 88E9 AB8E3512BA20 1D6F3FBF 26EF 45EF 9078 597E01AB4FD7 4966A183 5E01 4585 9767 7BF0C77069FE D2D90779 467C 41A1 B9D0 9350B33CAC8D 2A385411 E107 429D ADB1 25F3B1F7A081 1BB31883 CA3D 4967 B48D 3849271D782A 92F79CD1 FCF3 4156 97CA FAFD9FB19929 0CBC4D13 4CE6 420C 9A4F 12E5FE06BF36 437D85A4 9931 4708 8237 3DF489540A5F 05AA1495 AAF2 4AF9 9D4C 3F90E711709A DE96A85C 2EF4 414E BC58 95EF34CCD761
Plante11
Plante11
45
110
Maine
Welcome from South FL!
Nice rig!
Thats a dand detailed list of stuff u got there. U know its a honda right 😉
Everyone around here runs Can-Ams or Polaris. So I just want to make sure I have what I need to keep the other guys running so we don’t have to head back to the trailer 😜
105,595
Sounds like you're ready for Overlanding.
Reactions: JenElio
Plante11
Plante11
45
110
Maine
Think it's good camp list, skids is what he needs?
I have been looking into skids, harnesses, and LED cubes. I have to keep telling myself that it’s a slow build and the bank account will appreciate my patience
  • Haha
Reactions: JenElio
208,729
Skids!
Reactions: JenElio
105,595
UHMW 1/2' under armor best thing hands down and worth every cent!
Reactions: JenElio
Plante11
Plante11
45
110
Maine
Its on order, but mine has night vision too. I just plan to be the guy that keeps riding when everyone else has to go home...I mean, that’s why I bought a Honda
  • Haha
Reactions: JenElio
208,729
HA!😍
Reactions: JenElio
Plante11
Plante11
45
110
Maine
How could I forget! Shout out to everyone I get ideas from without them knowing, buy parts from etc. I also heard this add on is what really adds the extra ponies!
70B9DD9B BCE1 4373 A8AB FBFBE1349AEE
Reactions: JenElio and Mudwing
Similar threads
