P500 Oil Change
RumpRocket
189
295
USA
I messed up on ordering oil for the Honda Pioneer 500....I ordered Honda GN4 10W40 Oil instead of Honda GN4 10W30 Oil...any suggestions.....to use or not to use?
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
I just changed the oil on my 2016 p500 and used the 10w40 as well. Been using it in my 2015 Rubicon when the 10w30 wasn't in stock. No worries on the 10w40 at all.
The oil change was easy but getting to the oil filter was a PITA. The designer of that system is a sadistic individual.
Sent from my XT1650 using Tapatalk
AlR
AlR
470
1,166
Nanaimo, British Columbia
Just a bit of a temperature range difference. Unless you're in an extreme environment (very hot or very cold) you shouldn't have to worry.
My $0.02
Al
Reactions: RumpRocket
rocmar
rocmar
4,741
5,776
4 CORNERS
Checked oil before takeover, 1/2 quart low?? 500 miles.
Mine....also eats a little..
...no smoke..but yeah...
Fill it up....Ride it
....lol
Reactions: Mudder
RumpRocket
189
295
USA
I did my first oil change....I didn't find it all that difficult or time consuming.....I did notice it's a lot quieter..... I ordered up some 10w30 and used that instead of the 10W40....I plan on using the 10W40 this summer if it's a hot one
Reactions: rocmar
NitroxDiver
NitroxDiver
488
918
Concord NC
Don't we have a 500 mile service interval for the engine? So basically it's using half a quart between oil changes. A lot more than I would expect but probably not the end of the world. Did you do the 100 mile service?
43,292
Honda's "semi dry sump" engines can have the oil vary a bit depending on what procedure you use. You must follow what the owners manual states including runtime/temp and duplicate it every time. I saw this on the 700, and have already seen it on the 500.
Weber-dcoe
Weber-dcoe
5
7
Northern Wisconsin
Oil viscositys are not that complicated. My grandpa worked for Mobil back in the day and all the multi-Vis oils are what the first number sez. In your case, it's just 10 weight oil with the protection of a 40weight. In other words there are more additives within that bottle of 10w40 oil than 10w30. 5w30 is 5 weight oil with the protection of a 30w. etc...
Mudder
Mudder
NTC Ambassador of Walls
11,690
88,472
Yep, did the 100 mile, 600 and now 1200. With the move to synthetic, wondering if longer intervals could be ok?
