Does anyone know the difference between the p500 engine and the new one in the p520 besides a few more cc's ?
@906UP rebuilt his 500 to a 520 cc. He might be able to shed some light.Does anyone know the difference between the p500 engine and the new one in the p520 besides a few more cc's ?
Hi,
The only thing that I ever found through reading articles was an increase to the bore. The stroke, compression and throttle body are the same from the P500 to the P520.
Still, 43cc's from the increase in bore is a nice bump. Not quite 10%, but they didn't add that much weight either.
Rob
The difference is a 2mm larger bore, as @crewcabrob everything else is the same. I checked the part numbers for the TB, injector, even the ECU is the same, so I assume the fuel map is the same.@906UP rebuilt his 500 to a 520 cc. He might be able to shed some light.
Sounds like quite a job.I rebuilt the top end on mine this past winter, it's not a simple bolt on by any means. I ended splitting the cases and completely gutting the bottom end & trans, bolting the cases back together and machining the bore in the case to fit the 518cc cyl. Mine was ready for a top end anyways so it was a bit more work but I had time. I ordered all OEM parts from Honda..... cylinder, piston, rings & gaskets.
It's not quite that simple.....if it were then the Talon would only be 60hp +/- instead of 106 or whatever they are.Sounds like quite a job.
I couldn't find info on the HP or torque for the new machine. I had to extrapolate that 43cc's is about 8.3% of 518 cc's. I read that the p500 has 28.7hp so, if you add 8.3% to that, (2.3821hp), it would be 31.0821hp.
Rob
