Same set up I'm running. I leave the plow mount on yr round as it doesn't hinder ground clearance. That plate took a nasty hit and saved my front end when I hit a huge rock under water.
What's the width between the plow-mounting brackets? I gotta redo my Kolpin switchblade mount setup from underbelly to a front end mount after I put the SSS skidplate on, and dunno if I'll have time to learn how to weld before winter, lol.
Completed the plow today. I think this is a good quality plow. Had to drill two holes for the side shield, everything else was pre-drilled. I like the front mount over my ATV middle mount. This is going to be a big improvement over the ATV and plow I used last winter.
@Dave75 can attest to KFI being top drawer product! Have used mine for a number of years and they stand the test of time. As Trigger does I too leave the machine side mount on year round. Will say that periodically I check and tighten the side bolts as they work loose. Thought of locktite but just didn’t and on install used anti-seize paste on all bolts….
I also have pranged my mount a bit passenger side ears.. not a biggie though. On my P500 must be aware at full height can crease the front bumper, as the winch will raise the arms into the bumper. For me I think happened when pushing snow up into a pile and/or bank.
Enjoy cheers
