P500 tipping point
Code54
Code54
585
635
Hurricane West Virginia
We were talking about the P500 tipping on another forum so I did a little test yesterday. I tipped the 500 up (had a safety strap just incase I goofed) and wanted to see if it was easily flopped on its side. I never took it all the way to the tip point, I quit while it was stable and could not easily be pushed over. Here are some photos to give an idea of the tip angles. I got a rough reading of 30 degrees on an angle gauge and then lifted it a little more without it tipping.
IMG 0861 IMG 0865 IMG 0863
scott
scott
1,212
1,354
lyman, South Carolina
That's interesting. I have wondered about it too. With the 700 as well. I would end up turning mine on its side if I tested it lol. I have turned it on its side twice riding.
Code54
Code54
585
635
Funny you mentioned that - I ran a safety strap and kept about an 1"-2" of slack in it "Just in case"
Really didn't want to flop it over in the center of the garage.....
  • Haha
Reactions: Biteme
67,170
I thought about doing this too. Though I wouldn't mind trying it in a safe area... I do know 30 deg in the shop and 30 deg on the side of a mountain, looking down, is a totally different feeling that I'm not sure I want to be a part of. lol.
Another guy installed one of those manual meters. (forgot what it is called) to measure tipping point and marked his "red" zone.
Scott, you've been volunteered to do real world testing and report back in the 700 section. lol.
scott
scott
1,212
1,354
lol I hope I'm done with it. But it will probably happen some more. Get some deep dish rims and make if 5" wider lol.
Reactions: Biteme
And wear every ounce of mud that touches the tires!
Reactions: Biteme
scott
scott
1,212
1,354
Yea. I'm not doing that for sure. I hate cleaning it off. Whenever I get a lift and tires it might turn on side easier tho.
Reactions: Biteme
hambone
hambone
154
89
Southeast Indiana
Thanks Code!
I have had mine on two wheels goinG up a mountain, pretty sure if I let off throttle it would fell over.
When in doubt, more throttle!
Reactions: Biteme
It's called a inclinometer. Here's the one built in my f150.
00f22444a2b3bd08e78182dd16882657
They also make phone apps for inclinometers or you can purchase a dash mount.
Scott, I got you a sticker just in case.
Eb6d583f44b07807bb461e415587d536
I've thought about buying one and putting in in the shot from the GOPRO, video doesn't do hills justice.
You'll be about to roll over backwards and it looks almost flat.
That's very true and a pretty good idea. I've got the phone app but I don't want to mess with my phone mount and calibrating it before every ride as the mount may move.
Reactions: Biteme
scott
scott
1,212
1,354
Lol I know I know. That other guy that turned on side at windrock does also. Lol where he turned over was a bad spot tho. The spot I did wasn't I was playing around and it bit me. Lol
Reactions: Biteme
BurntMudd
BurntMudd
Flipped mine only after having it few weeks. Easy to stand back up! Had it less then a week and put over 50 miles on it, with in 60 acres! Very happy with it
