P500 P500 WHEEL SPACERS RIDE?
Steve00
Steve00
64
91
Florida
Will adding 1.5" wheel spacers improve my ride on whoops that much better? Also, is there a REAL difference in ride between 1.5" and 2" spacers in ride?
When wheel spacers come in "I ordered 1.5" I'm also going to remove the sway bar I'm hoping no sway bar and 1.5 all 4 wheels I can save myself from THE TORCHER CHAMBER! AKA p500 lol
Fatsquatch
Fatsquatch
Approved Member
121,250
1,010,947
Hidden
Maybe I'm wrong, but I don't see how spacers are going to improve the ride quality at all. They will help you keep it on all four wheels in corners or off camber stuff. Hopefully I will learn something watching others reply though.
HUCK
HUCK
1,047
2,319
ARIZONA
Spacers will not change the ride as far as smoothness goes . NOTHING will really , it's a Pioneer 500 . It is what it is . That being said .
Disconnecting the sway bar and lowering your air pressure will be the biggest ride improvement you can do for a smoother ride .
The good news is . BOTH FREE
Bastardchild
Bastardchild
1,978
7,252
Orange Heights, fl
I can kinda see how you might think it would make your suspension softer, being the wheel would be 1.5" farther away from the hinge point where the a-arms bolt to the frame, the suspension would have to offer a slightly softer ride. It would make the suspension easier to compress, just like a wrench with a longer handle will break a bolt loose easier than a wrench with a short handle. Also, the long travel a-arm kit requires aftermarket shocks I believe because the stock shocks get compressed too far from the extra leverage of the longer arms, so spacers would kinda be like longer arms, but not that extreme. I know this doesnt answer your question, but going wider on a P5 is always a good thing, and if it does help you from getting beat to death from your suspension let us know. Lol
Steve00
Steve00
64
91
Florida
yes and yes! wheel spacers did soften up shocks more! tested it out, it allowed me to adjust WE shocks and get a better ride tried with and without.... With wheel spacers and playing with the clicker and preloads wheels spacers helped and added a little stability after I removed sway bar!
bhewett102
bhewett102
5
19
Holden Beach,NC
With the sway bar disconnect and 2 inch wheel spacers I noticed a definite Improvement in the ride on my P5.
The biggest difference was when I put the Walker Evans shocks on. When you are riding in Rocky Terrain it is definitely worth the money but it's still a P5 not a Talon.
monaco
monaco
376
982
Indiana
bit.ly
For me, unhook
For me, unhooking the sway bar helped, then adding the 2" spacers did a whole lot more for side-to-side stability and less "tippy" times. It's more than enough to notice, and everything is more secure on slanted trails.
monaco
monaco
376
982
Indiana
bit.ly
I'll have to try the shock upgrade someday
Jbutler
6
6
Maricopa, AZ
For me, unhook
You are correct! it helps your stability and stance! I would not ride without them now...
Russ989
Russ989
22,645
147,291
Those were my thoughts as well, all P5’s need spacers in my opinion.
SamHyde
SamHyde
9
23
Walker, WV
I'm looking at a set of wheels with a 5+2 offset. I know that will help, but I expect I will at least add 1" spacers in addition to that. Any thoughts?
Reactions: rtn001
NitroxDiver
NitroxDiver
488
918
Concord NC
I was running 2” rear 1” front spacers on the factory wheels but recently went to 5+2 and used the same spacers on those. You may want to try 1” spacers on the rear first and then if you decide you want to go wider you can move them to the front and add 1.5” or 2” to the back. I believe you will find you need a little more spacer on the back to even things out but that will depend on the tires you choose too.
Reactions: rtn001
195,424
Some things not mentioned in this thread are tire size...some run wider tires in back, some run skinny's on all four and some run wide's. Another consideration is comfort level for the stability...have always tried to keep it as narrow as possible while maintaining stability.
Last would be track width...having an even track is more of a preference thing and having an inch or two difference front to back probably doesn't impact the performance of the machine at all. My 2c is that it looks stupid if it's noticeable. Also when you're deep in the sh**, straddling ruts that are as deep as the machine is tall, it's nice to know the a** end is taking the same line. FWIW ;)
SamHyde
SamHyde
9
23
Walker, WV
I do run wider tires in the back, and will likely continue to do so. Depending on the setup, a rear spacer may not be needed. I'll just have to take a look once I've got things settled and go from there.
1.5’s didn’t do anything to improve my ride quality, but they did add a level of stability to that venerable little tippy rascal.
Reactions: Jbutler
