P1000m5 PBR switch panel fasteners
W
Wsmithgunworks
9
North Central Arkansas
I just bought a 2021 1K5 LE and am planning on adding a few accessories that require switches. So, I bought the PBR switch panel and really do not want to use the rivets to fasten it to the dash. I've looked through the forum and haven't found any ideas....I'd like to have access to the back of the panel just in case I have to do any work on the back of switches....any ideas or links to other discussions?
ProudDadOf5
ProudDadOf5
3,122
24,208
Winfield, WV
You can easily access the back of the panel from under the hood and pop your rockers out or whathaveya with the rivets provided.. I’ve swapped out and added rockers once installed with no issues..
Hot94Z28
Hot94Z28
78
107
Lexington Missouri
I just installed their panel yesterday and say I really like the build.
I used the rivets, the back is pretty easy to get to, but if you need to pull it just drill them out and install new rivets. Or if you end up having to pull it more than you would like replace the rivets with something easier to pull the panel.
TripleB
TripleB
14,344
126,214
Caryville, Tennessee
I use rivet nuts and Allen head screws.
Dirtstiffs-1000
Dirtstiffs-1000
1,646
5,991
hondasxs.com
I used stainless screws and lock nuts to slow the thieves
20191026 170832
BobRack
42
92
Arkansas
Drill out rivet holes with 5/16 drill bit and use the 8mm plastic body rivets to install plate. That's how I've done mine on P700
20200303 160521
cornbiscuits
cornbiscuits
12
40
Warrenton, Mo
I drilled out the rivets that holds the warning label on, then installed 10-32 rivet nuts and bolted it on using black stainless steel button head screws. Matches all the rest of the factory hardware. (other than being metric, but u cant tell that by eye anyway.)
cornbiscuits
cornbiscuits
12
40
Warrenton, Mo
I was worried that the push pins wouldn't hold the panel tight against the dash enough to prevent rattling, but I guess this isn't the case? Does anybody experience rattling using push pins?
PatioDaddyo58
PatioDaddyo58
48
95
Abilene, TX
I didn't want to rivet mine down, either, so I used M5 screws. I didn't use any fasteners on the back side because I couldn't get my big ol hands in there. No issues, though.
PBR panel
Reactions: ProudDadOf5
TI722
TI722
111
650
IL
  2. Other Brand
do yourself a favor and order some of these because the rocker switches provided suck.
