I'm interested in the roof mount you have in the photo. What mounts did you use for that?
Your light a Black Oak?Braced it off the windshield. You could brace it off the ROPS
Made from ⅛ steel flat-bar
Or a P1 low mount. I want to mount below head lights. And I really don't understand the ratings on Led lights. Looking at a 20 inch curved Black Oak comboGreetings,
Anybody have any photos of light bars installed on their P700?
Thank you in advance.
What's the degree patterns between the two ?Or a P1 low mount. I want to mount below head lights. And I really don't understand the ratings on Led lights. Looking at a 20 inch curved Black Oak combo
5 Watt 3 Watt
Wattage 200w 120w
Amp 8.4 8.1
Led Qty 40 40
Lumens 22,000 12.440
IP rating IP69k IP69
E-mark E9 E9
Can any one explain this to me, 3 Watt $ 364.00 5 Watt $ 425.00, comes with every thing for wiring. Think I would need the 5 Watt? Thanks!
Don't know other than the outside lights are floodWhat's the degree patterns between the two ?
Do they come with relay, switch, fuse and wiring harness ?FWIW I've always used autofeel or auxbeam light bars and never had a issue and much cheaper.
Guess not. Brand of light. Does any one understand the goblei goop I posted about the lights?????
The double harness is only 15 bucks.Do they come with relay, switch, fuse and wiring harness ?
5 Watt 3 Watt
Wattage 200w 120w
Amp 8.4 8.1
Led Qty 40 40
E-mark E9 E9
Got a link to the one you are looking at ?Don't know other than the outside lights are flood
correct but is the 5w is a 60* spot and the 3w is a 20* spot the id go with the 3w cause it'll have a more controlled light which makes a huge difference.3w LEDs vs 5w LEDs
5 should be brighter
Here’s 35000 lumens in an 18” bar with 4 levels of brightness.
MTN LITEbar - 18" - V54 Spec.
