P1000 Pin hole in sidewall
BBLASER
159
277
Phoenix
Ok, I put on new tires and immediately got a pin hole in the inside sidewall. It is so small that it takes overnight to drop 4lbs of pressure. What should I do? I am not 100% sure if it came like that or if I really have that bad of luck. I did notice that one of the tires that came mounted up was considerably less inflated than the other 3 but I never thought much of it. The only way I found the pinhole was spraying soapy water on it and finding the bubble. Can Slime fix this or should I just get a new tire?
Reactions: Isaiah and Biteme
hondabob
1,281
5,088
Prescott Valley, AZ
You can patch it on the inside or plug it. With a plug you have to be careful not to scrape the plug out. It may take a lot of slime if its not at the tread.
Major0887
Major0887
30
60
Arizona
There’s a tire sealant called “tireject” they sell it on amazon. It’s can seal sidewall holes up to 3/8”. I’ve been running it in my tires for about a year now with no issues. Hope this helps
60,931
Have you ridden on them at all? If you got them from somewhere already mounted on wheels and have never rode on them I'd bring it up with the seller to make it right. If you rode around on them, it's on you. If they are beadlocks or you've got a beadbreaker to install them yourself I'd patch it and then throw Slime in it.
rickoshea
i run mine with tireject.i'm assuming it will plug it,i've never dropped a single psi so i'm guessing it works 🤣
115,817
I had a brand new tire get the side wall punctured at the takeover last year and it really pissed me off cuz we all moved Over for a few poo poo’s to get buy while we were having lunch! They could hear it hissing and just drove by pointing:mad:
Anyway, a sidewall picture doesn't give many options to fix it. My solution was to get an inter tube for 15$ The size of the tire, mine was 30”. It was Cheaper than vulcanizing (good option too) and worked very well. Haven’t had an issue since. Good to note that I used a patch first an for off road didn’t work worth a dam
Reactions: Isaiah
Russ989
Russ989
22,642
147,257
^^^^^THIS^^^^^
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
I jabbed something in my sidewall 2 years ago. Out on the trail I did the only thing I could do. I put three plugs in it and used slime to inflate the tire.
I forgot about it for a couple of weeks and since it was holding I decided to let-r-ride. It's still holding today.
Reactions: CID and TripleB
RoundMtn
31
82
Maine
Big hole last night riding and 5 plugs later and jug of slime to get me home... anyway just picked up the tire from dealer with new tube .... hope it holds
Haldog77
Haldog77
NTC's Mafia Enforcer
39,887
346,450
Bossier City, Louisiana
Either of these is what I have had great success with.
07DD5EED 729F 40EB B469 80913ADAAC76
Reactions: Dirtstiffs-1000
BBLASER
159
277
Phoenix
A little update. I ordered up the Tireject and it sealed up perfectly. I turned in a warranty claim to Rocky mountain ATV, but with the COVID, their response was delayed. I did not want my SxS sitting for weeks on end, so I just put the tireject in and forgot about it. 3 weeks later, RMATV reached out and warrantied the tire. I was pleasantly suprised. They shipped out a new tire and gave me a gift card for 20$ to get it mounted at my local tire shop. Shout out to RMATV on their customer service. I am out a bottle of TIreject, but that is small beans compared to a compromised sidewall.
208,728
Just buy ITP tires, on my second set, no flats.
