P1000 Pioneer 1000 deluxe lift
Pellicer96
Pellicer96
75
166
Lyons
Have a 2016 pioneer with the super atv 3” lift consisting of spring brackets and front spring spacer. Went on a ride yesterday and broke an axle. After installing lift I noticed my axles were at a horrible angle and I’m sure that’s why my axle broke has anyone changed axles or added different lift to solve this issue
Reactions: sharp
DDDonkey
I have a 2" lift and have never had a problem, but I pay attention to the loud pedal when in 4wd or 4wd lock. I just put on the SATV front and rear a-arms with out the steering stops and noticed no bind a full droop with the 2" lift but going much past that there is bind. I also found out the at full lock the axles are binding without the steering stops. You were prob at the limit of your cv angles unfortunately. The SATV axles are suppose to be stronger and have more articulation at the CV, I just order a set for this reason.
Reactions: sharp
RickPerrin3
RickPerrin3
Miami
What size tires do you run with the 2” lift and SATV arms? Assuming 30”s?
Reactions: sharp
Rambo
Rambo
339
822
Southern Indiana
Who makes the 2 inch lift?
Reactions: sharp
DDDonkey
With the highlifter, lift I am running 28.5” truck tires (235/75r15). I have had this set up for the last 500 miles or so before adding the a-arms. I only have about 10 miles with both the a-arms and lift installed.
aauman88
aauman88
1,091
2,846
His lift kit had brackets and shock spacers. He’s running stock wheels becasue he just got it. We had big ride yesterday and one things for sure, he’s not scared of any of the holes. One of the holes it took 15,000lbs of winch power to pull him out. It was our first ride so we will be much better prepared for next one. He broke an axle but that was it between us
254A8E5B 1AD3 4B95 9F74 DB7542FAD87E 7FACF52F 6CE2 460F 8406 0F770CAF3019 AE6EE9A4 FCC7 448E B8F0 570A7C740218 3D42C88E 6AD0 4830 88A9 712A56349E21 17A26A45 FB67 4EDE BB2C 0EBA331E42A5 71596FFC 61E7 4061 9CCB ADF6FEEA323D 873FB281 0833 4C07 BD79 726D148719F8 7D7C7FDD 6B21 4017 9071 AB1C0DBFCCAE
Pellicer96
Pellicer96
75
166
Lyons
Had our second ride Saturday with my new rhino axles and I noticed the axle has a lot more motion and allowance over factory axle very well pleased also first run with viper 6000# winch great product and company she got a full bath after this ride
60A60F47 B2D3 46D6 9819 BDB5C2BCA5FD 7FE925F2 8DAB 4B6B 83EC BDE015BBECFD FEB280B3 77E1 440B B6EB 282577856BF0 3772B0B9 13B1 4926 B894 644FC8C1F1D7 AD0A3CD4 6374 48BB AF2E 6468F1A98840 CFB09218 538E 4650 BD7F F4BEBE09BFF9 BD688BA1 0257 4576 ADC5 7FE4E5924E62 695B6D28 BB70 4E6A A976 626A4092B288 0B105521 877B 4879 AEBA 4B89FE6553C6
Pellicer96
Pellicer96
75
166
Lyons
We 1 for 1 I broke axle and you broke winch
View attachment 119991 View attachment 119992 View attachment 119993 View attachment 119994 View attachment 119995 View attachment 119996 View attachment 119997 View attachment 119998 View attachment 119999
That’s a deep clean!!
@joeymt33 can’t say he cleans his machine anymore.
