P1000 Pioneer 1000 Terra45 Winch Install.
63,330
Finally got around to installing the Super Winch Terra 45 with the KFI Winch Mount with a PDM-60 power management device.
Here is my layout. Hope it helps someone. I will update this as questions are asked and answered.
I have no plans at current to install a second battery
Winch Wiring Layout.
Winch
IMG 6643IMG 6661
IMG 6662IMG 6719
Mounted the PDM-60 and the Ground Bus.
Ground wire was ran to the ground bus. Ground trigger is not currently connected but I may run it sometime for a backup light.
IMG 6666Groundbus
Looked up the Honda Switch Panel Instructions. This is where Honda splices to get "Key-On" power. I placed a tap-in here. Recommend using a Posi-Tap for a more error free connection.
IMG 66471000 key onIMG 6658
Next... Switch install.
Cut a hole for my switch plate and wired up my 5 switches.
Yellow is to the illumination from the headlight switch wire. It is jumped from one switch to another.
Black is ground wire, it is also jumped from one switch to another.
Left over "blank" ports are for power IN from PDM-60 and power OUT when switch is "ON"
IMG 6676IMG 6670
Here are the switches I used:
Here is the location for the illumination power source from the headlights.
Brown wire is taillights, it is always on when headlights are on Hi or Low.
IMG 6641IMG 6639
Next.... Winch Mount Install.
Finished ruing all the wires and started on the winch install.
Removed front bumper.
IMG 6681
Installed the bottom mount.
IMG 6686
Mounted the two back winch bolts to the top plate.
IMG 6687
Placed plate and installed the front winch bolts. Had to get longer bolts from ACE.
IMG 6688IMG 6691IMG 6702
Few more pictures finishing up the install.
IMG 6705IMG 6708 IMG 6716 IMG 6717 IMG 6718 IMG 6720 IMG 6721 IMG 6722 IMG 6698
What did I leave out?
Here is the items I used and where to buy them:
PDM-60 - Rowe Electronic's PDM60 Power Distribution Module
Super Winch Terra 45 - Superwinch 1145230 Terra 45 4500lbs
KFI Winch Mount - KFI Products 101285 Winch Mount For Honda Pioneer 1000
Note: I do not claim to be a expert on wiring. I have only my past experience to go on. Therefor, I state there are many methods and routes to install a winch. Above is only to show my method. Duplicate at your own risk. You can also replace the PDM-60 with a relay switch type system but the same general layout can apply.
Johnny_C
Johnny_C
303
143
Western N. Carolina
Great write up.
Would you list the part numbers/
descriptions of those switches?
I am still confused by OTTRATTW
descriptions.
Thanks!
John
Reactions: Hondasxs
63,330
Post configuration instructions are sent with each switch.
I will add this info above later.
Reactions: pct and Johnny_C
ofrcboy
ofrcboy
501
572
Oregon
Looks like it fits but I don't like the way the rope runs up and over the fairlead. I will wait for the EMP front bumper top mount so I can see the winch, reach control and watch rope wind on the spool.
63,330
Yep. I took those last pictures just to show that. I may change it around too once something else is out.
N
Ned
241
183
West Kentucky
Your ground buss? I'm trying to get a good look at what you did there?
63,330
It came with the PDM60. I will get some more pictures tonight of it.
You can see it in the picture below. It's the short black wire with the plastic cover. I just secured it into the frame. Then you can easily connect all your grounds.
Johnny_C
Johnny_C
303
143
Western N. Carolina
Thanks!
That will really help!
John
Kenjones21
Kenjones21
164
103
Central Louisiana
Questions?
Great write up!! you didn't leave it out but I was wondering how you got the slack in the wire harness for keyed power, I see that it has some type of clips holding them down but couldn't figure out how to remove them .
63,330
As for the winch one way or the other. I just felt it fit best this way. No other reason.
For the OEM fuse box. I just pulled on the box and it came unhooked. Then unwrapped some of the elec. tape for more access. It popped right back in. I'm sure there is a clip to push.
63,330
Oohh. I ment #8 and #13. Breaker and holder.
It should be in there. If not. There fairly cheap.
Calvin
Calvin
42
Benton, La.
Questions?
Did you run the feed to your lighted switches straight from brown wire that is hot when low or high beams on? Or did u run it through a relay and to battery? Also if I got this dual lighted usb charger could I feed it with same wire coming from brown wire feeding my switches or would that require to much amp pull from brown wire?
