• Welcome to HONDASXS.com
    If you are a guest please take time to REGISTER with us. Stay up to date on the Honda Side by Side line and take part in our online forum. Check out the FAQ. Once you register you can start to make post. Users will respond to your question or statement. To start viewing messages, select the forum that you want to visit below or click the board index to see a list of all forums. Thanks and have fun.
Talon Plastic trim clip removal
Discussion in 'General Talon 1000 Discussion' started by Oldmxrat, Oct 9, 2019.
  1. Oldmxrat
    Oldmxrat New Member
    Reno
    Ownership:
    Talon R
    While installing accessories I've encountered a number of difficult to remove trim clips, because of their location, where the usual tool just doesn't work. For the ones with the pry slots I've found that a paint can opener is just the ticket. I ground the edge a little sharper and it's super easy to get it in and pry them out, even in hard to reach places.
    For the ones with the smaller center and no pry slots, just push in the center and the whole thing comes out easily(found that out the hard way).
    I hope this save someone the same kind of frustration I had dealing with these things. clips1.jpg clips2.jpg clips3.jpg
    JimmyTalon, BeezrGeezr and lee like this.
  2. MFG
    MFG Active Member
    Mar 14, 2019
    110
    172
    East Texas
    Ownership:
    Talon R
    Amazon has a plastic rivet tool for about $5 bucks that do the pull up style. It works great.
  3. Cyberjunk
    Cyberjunk Berserker
    May 10, 2017
    1,506
    4,946
    Crane Hill Alabama
    Ownership:
    700-4
    Make your own with a cheep slip joint pliers . Take a side grinder and open the pliers and grind a slot on both sides leaving a thin ridge to grip the head and pull.
  4. stellarpod
    stellarpod Well-Known Member
    Apr 18, 2019
    325
    942
    OKC, OK - USA
    Ownership:
    Talon X
    I often use a pair of side cutters, allowing the beveled jaws to slip under the head while *carefully* squeezing them. Prys the fastener up without a problem. Of course you've got to be careful not to cut the head off.... ;)
    Steve
  5. hurld
    hurld Active Member
    Feb 19, 2014
    117
    108
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
    Dismiss Notice
Loading...
