Multi Poll - Valve Adjustment or not
Valve Adjustment, have you done it?
  • Yes, for preventative maintenance as stated in manual
    Votes: 20 28.6%
  • No, don’t intend to unless serious valve noise develops
    Votes: 44 62.9%
  • Yes, only after significant noise had developed
    Votes: 4 5.7%
  • P500
    Votes: 36 51.4%
  • P700
    Votes: 9 12.9%
  • P1000
    Votes: 10 14.3%
  • Big Red
    Votes: 0 0.0%
  • Total voters
    70
Mudder
Mudder
NTC Ambassador of Walls
11,593
87,207
Reading a valve adjustment thread got me wondering. Not to repeat the pros or cons from that thread, just curious about actual experience by Honda owners. If yes, was it out of specs?
sam3006
sam3006
144
411
Damascus, AR
Mine is a 2015 that I bought in the summer of 2014 as soon as they came out. It's got around 2500 miles on it and has never ticks or shown any sign of valves needing adjustment. Besides adding options to it I've done nothing mechanical to it, only regular service of oil and filters.
JWB
JWB
2,014
California MD
Valve clearance doesn't generally get looser-noisier, with use, the clearance generally gets tighter-quieter, as the valves recede into the head as the seats and valve faces wear in. I've found particularly with the V-6 Hondas, that a valve adjustment at between 300-400 hrs very often makes them run a whole lot better, less noticeable with the three and four cylinder engines. If the valve clearance gets below minimum spec, they tend to be a little harder starting, and don't idle as well as a properly adjusted valve-train. Worst case, the clearance goes away completely, and it starts to burn the valves and seats prematurely because the valves don't shut completely. I haven't seen a single valve that was looser than max spec, and I've checked literally hundreds- but all my Honda experience is with the marine engines. I guess my point is that it's worth the effort to check/adjust the valve clearance, and always adjust them to the loosest spec.
Reactions: Morpheus
BuckCreek01
BuckCreek01
279
488
Griffin Ga.
I was on the fence but decided to take my P5 to the dealer for the first service due to the extended warranty contract. I requested for the valves to be checked also. Will edit my post with specs when I have the receipt in hand.
IN = 0.14mm = .0055"
EX = 0.21mm = .0083"
No adjustment stated.
