Ok I may get some, lifetime Warranty on the portals right?
Im usually not one to bash someones product....but .......i have spent the last 2.5 hrs trying to make this POS fit on my machine. Right off the bat there were no instructions...no biggie i download online. Pretty straightforward install anyway... the main bracket holes are cut at least a 16th off. Again no biggie..rattail file and main bracket on. The front AArm tabs are cut to the wrong angle and misalligned. When i put the bolts in and tighten them it pinches the A arms bolts. So if i was to have problems with my arm i would uave to loosen the entire frame kit. Yalls QC needs to step up a couple notches. I have bought alot of SuperATV stuff and hate to bash one of your products....bit this one is crap and will be going back!
And just for the record i read several reviews that stated the same issues i have. I just really hoped that it wouldn't be the case with mine.
To be fair...i did finally get it on that night. I posted that out of frustration and had already spoken to tech support and told them i was going to return it. But after several more beers i wasnt going to be beaten. It took alot of tweaking. So someone buying this need be aware that this will probably not be a straight up bolt on process...unless you have a brand new never driven machine. Overall I think it will be a good upgrade.Man, frame stiffeners are the biggest PIA install. Mostly because its designed to run on a brand new show room floor model that hasn't been beaten up at all. The flimsy stock frame tabs get beaten up pretty quick, and they make that install a real pain. But...having that on there will protect them for the long haul. For some of the older machines that have seen some abuse, I always just say to beat the hell out of it until you can get it to fit. Frame to frame variation isn't bad but isn't perfect, but the main issue is trying to get it on when you already have a little damage. The frame stiffener, a skid plate, and a winch would be the absolute first things I'd do to a brand new machine.
Good luck.Im usually not one to bash someones product....but .......i have spent the last 2.5 hrs trying to make this POS fit on my machine. Right off the bat there were no instructions...no biggie i download online. Pretty straightforward install anyway... the main bracket holes are cut at least a 16th off. Again no biggie..rattail file and main bracket on. The front AArm tabs are cut to the wrong angle and misalligned. When i put the bolts in and tighten them it pinches the A arms bolts. So if i was to have problems with my arm i would uave to loosen the entire frame kit. Yalls QC needs to step up a couple notches. I have bought alot of SuperATV stuff and hate to bash one of your products....bit this one is crap and will be going back!
